3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
HDDJ: Turning an old hard disk drive into a rotary input device
Step 2Solder wires to the spindle motor contacts
Turn the HDD over, with the exposed platters facing down. Some older HDDs will have four wires coming out of the back of the spindle motor, in which case you can skip this step. Most, however, have an orangy-transparent flat-flex cable. In this case, what we are looking for are four exposed contacts at the back of the motor that we can solder some wires to.
6 comments
Nov 30, 2011. 7:00 PMRhamkota says:
What if my hard drive only has 3 connections to the motor
Feb 5, 2012. 10:45 AMvadipp says:
Then you should find the "center" one using an Ohmmeter and _not_ use that one. See the right image in http://en.wikipedia.org/wiki/File:Wye-delta.svg
Feb 5, 2012. 10:57 AMvadipp says:
Hmmm, I just realized that this project relies on all four wires. Sorry, I don't know how to fix it :)
May 11, 2010. 12:50 PMproject dude says:
 Solder what kind of cables, standard electrical cables or audio or video cables?
Jun 28, 2011. 7:18 PMData643 says:
There isn't much of a difference between the two...
Feb 23, 2011. 1:43 PMrecordmasta001 says:
22 gauge wire will do fine :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:nvillar
