Step 6Schematics and firmware for the HDDJ device
How to test the HDDJ Device
1. Install the driver provided in the ZIP file
2. Plug in the HDDJ to a USB port of your computer (it will mount as a virtual serial connection, and assign it a COM port)
3. Use a terminal program (like Putty) to connect to the COM port, at 115200bps, 8 data bits, no parity bit, and one stop bit.
4. Try spinning the HDDJ platter: you should see a stream of '<' characters appear as it spins counter-clockwise, and '>' characters as it spins clockwise. The frequency of characters will depend on the velocity of spin.
5. Moving the fader will output the character 'f' followed by a number between 0 and 100. To control the position of the fader type the character m into the terminal window, followed by a number between 0 and 100, and then hit return.
6. Pressing the buttons will output the character 'b' followed by a number between 0 and 8. To turn the LEDs on and off type the character l into the terminal window, followed by a number between 0 and 6, and then hit return.
For our project we wrote a bit of software that communicated with the HDDJ via the USB serial line using this protocol. It would be a relatively small (but useful) step to adapt it to, for example, translate the control sequences MIDI messages, which would let you use the HDDJ with generic music or VJ'ing software out of the box.
HDDJ.zip210 KB| « Previous Step | Download PDFView All Steps | Next Step » |
If you are a beginner of PIC, I'll recommand you an easy book.
Add me up as a MSN friend, "staybesideyou@hotmail.com"
Partlist
Exported from hddj-2.0.sch at 4/23/2010 4:52:42 PM
EAGLE Version 5.3.0 Copyright (c) 1988-2008 CadSoft
Part Value Device Package Library Sheet
B1 RB1A RB1A rectifier 1
C1 CPOL-USCT3216 CT3216 rcl 1
C2 0.1uF C_0805 C0805 rc-master 1
C3 0.1uF C_0805 C0805 rc-master 1
C4 0.1uF C_0805 C0805 rc-master 1
C5 470nF C_0805 C0805 rc-master 1
C6 0.33uF CPOL-USB/3528-21R B/3528-21R rcl 1
C7 22pF C_0805 C0805 rc-master 1
C8 22pF C_0805 C0805 rc-master 1
C9 CPOL-USCT3216 CT3216 rcl 1
C10 CPOL-USCT3216 CT3216 rcl 1
D1 BAT64_05 DIODE-2AC|CASOT23 SOT23 diode 1
D2 D-SMB SMB semicon-smd-ipc 1
D3 D-SMB SMB semicon-smd-ipc 1
J1 PN61729 PN61729 con-berg 1
J2 MA04-1 MA04-1 con-lstb 1
J3 MA06-1 MA06-1 con-lstb 1
J4 MA06-1 MA06-1 con-lstb 1
J5 MA05-1 MA05-1 con-lstb 1
J6 PINHDR2 PINHDR2 1X02 dongle 1
J7 PINHDR2 PINHDR2 1X02 dongle 1
J8 PINHDR2 PINHDR2 1X02 dongle 1
J9 MA06-1 MA06-1 con-lstb 1
J10 DC21P DC21P DCSKTP dcsocket 1
J11 MA04-1 MA04-1 con-lstb 1
L1 FB_0805 FB_0805 L0805 rc-master 1
L2 FB_0805 FB_0805 L0805 rc-master 1
R1 0R R_0805 R0805 rc-master 1
R2 DNF R_0805 R0805 rc-master 1
R3 22R R_0805 R0805 rc-master 1
R4 22R R_0805 R0805 rc-master 1
R5 470R R_0805 R0805 rc-master 1
R6 470R R_0805 R0805 rc-master 1
R7 470R R_0805 R0805 rc-master 1
R8 470R R_0805 R0805 rc-master 1
R9 470R R_0805 R0805 rc-master 1
R10 470R R_0805 R0805 rc-master 1
R11 1K R_0805 R0805 rc-master 1
R12 1K R_0805 R0805 rc-master 1
R13 1K R_0805 R0805 rc-master 1
R14 10K R_0805 R0805 rc-master 1
R15 10K R_0805 R0805 rc-master 1
R16 10K R_0805 R0805 rc-master 1
R17 4.7K? R_0805 R0805 rc-master 1
R18 10K R_0805 R0805 rc-master 1
R19 10K R_0805 R0805 rc-master 1
R20 10K R_0805 R0805 rc-master 1
R21 10K R_0805 R0805 rc-master 1
R22 10K R_0805 R0805 rc-master 1
R23 10K R_0805 R0805 rc-master 1
R24 10K R_0805 R0805 rc-master 1
R25 0R R_0805 R0805 rc-master 1
R26 DNF R_0805 R0805 rc-master 1
R27 10K R_0805 R0805 rc-master 1
R28 10K R_0805 R0805 rc-master 1
R29 47K R_0805 R0805 rc-master 1
U1 PIC18F4550PT PIC18F4550PT PQFP-44 dongle 1
U2 LM324D LM324D SO14 linear 1
U3 L78MXXCDT L78MXXCDT DPACK_3 dongle 1
U4 L293E DIL16 texas 1
Y1 4MHz XTAL/S QS special 1
Old HDD disk drive
Thats it?
