HDTV Antenna constructed of baling wire and duct tape - CHEAP by weblar
More and more people are foregoing cable and satellite television to save a bit of family income, realizing that there is plenty of free television out there to watch.  Many of those people are purchasing overpriced and underperforming commercial HDTV antennae, when you can make a simple antenna yourself out of an inexpensive 3' or 4' long 1" X 4" or 2" X 4" board, some short wood screws and washers, and some inexpensive metallic wire (galvanized "baling" wire works just fine), and a couple of short pieces of tape (electrical tape; or if you want to truly construct a quality product, of course consider duct tape to go with your selection of baling wire).  You also want to find a piece of heavy cardboard about 2' X 3' in size, enough aluminum foil to cover one side of the cardboard, and some spray mount or other adhesive to glue the aluminum foil to the cardboard.
As far as tools go, you'll need a drill with a bit to match the size of your screws, a screwdriver to match your screw heads, needlenose or pointed pliers, and wirecutters.
As explained in the OPTIONAL last step, it is possible to construct two of these antennae facing different directions and obtain signal from multiple sources and directions.
This is a variation of the plans that are found on-line at another website at http://www.tvantennaplans.com/
Step 1: Measure - mark - drill your board
Measure and mark your board in the manner shown, and pre-drill with the appropriate size drill bit starter holes for the screws that will hold the antenna to the board, which essentially forms the "spine" for your antenna
SOFISINTOWN says: Sep 16, 2012. 11:11 AM
I made it with fencing wire and it works GREAT!
I get a lot more channels than before, and all crystal clear.
I did not add the reflector, and I wrapped the whole thing with electric tape.
Thank you so much!
ktriplej says: Sep 15, 2012. 8:15 AM
I built one out of scraps and all I can say is thank you. It works!
silvermoon_wind says: Aug 22, 2011. 1:30 PM
I made one...a smaller version that hangs on an interior wall. Without the backing. Smaller...only 16" long but every single channel still comes in. Pretty cool!!!!
rocketman221 says: May 14, 2011. 5:15 PM
Nicely Done.
MacGyver would be proud.
cpotoso says: May 5, 2011. 11:50 AM
I have built a similar antenna and it works EXTREMELY WELL in the UHF, but not so well (for the sizes of this particular model) in VHF.
weblar (author) says: May 5, 2011. 12:16 PM
One of the comments I read relating to the original design that I modified for this Instructable was that the lengths of wires for the "Vs" in the original design favored either UHF or VHF (right now, I don't recall which); but the commentator suggested the alternative wire lengths in order to accomodate a broader range of signal.
I am able to pick up and watch television stations from Channel 2 (the lowest station I can pick up, and one of the stations further away from me - over 130 miles) to Channel 50 (the highest available station, and again far away - over 150 miles) using the antenna dimensions/wire lengths depicted in this Instructable.
cpotoso says: May 5, 2011. 2:15 PM
Excellent! I am quite sure the lengths you are using are best for UHF, but then again, you know it works and that's what counts!
When I built an antenna like yours (almost identical!) it worked very well in the UHF but I could not get any VHF. Then the design I used for a DIY VHF was more like this:
http://www.qsl.net/sv1bsx/6EL-VHF/6EL_VHF.html
I built it out of wood and some copper wires and put it in the attic, and worked wonderfully well.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
