Note: The antenna works independently from the dish, I'm just using the dish as a mounting device and since it's already wired to the living room works great for me.
Remove these ads by
Signing UpStep 1Materials
Screws and washers, assorted ones
Standard wire mesh or similar wire screen, can use a metal rack shelves, chicken wire, etc. mine is 24" x 14"
Coaxial cable connection plug.
1 piece of wood, can be 2"x2" ir 2"x4" 14" to 16" long.
and of course a used Direct Tv or similar Dish.
soldier gun and electrical tape.
Note: I did mine with only 3 pairs of "Vs" (or ears if you may) but I have seen other antennas with 4 or 6 pair, which I guess incresses the reception.
Not sure why the chickenwire backplane would ever be needed, unless it's to increase the overall dimensions of the reflector - although these dishes appear to be made strictly of fibreglass or other plastics, they are still required to be inherently RF-reflective, and, therefore, metallic in some regard, or they wouldn't work at all...
Most are built using one of these methods:
1. "DIY screen" - aluminim sheet is punched with a gazillion tiny holes, making a "screen" of it, then it's stamped into a semiparabolic shape and powder-coated.
2. wire-mesh "sandwich" on fibreglass "bread" - pre-made metallic screening or "wire cloth" is laminated with fibreglass and resins and stamped into a semiparabolic shape.
3. "soup mix" - metal powder is blended directly into the resins, resulting in a conductive plastic, which is then molded or stamped, etc....
thanks
This assumes that, as froggyman mentioned, there's no electrical connection between the "screen" and the pickup elements. If such a connection WERE needed, you'd need the chicken wire, after all, as it can be a considerable challenge getting at the conductive part(s) of the dish's own architecture.
I also wondered:
Would a single "V", standing-off the dish at the same "focal point" where the original LNB pickup was hung, perhaps gain enough from the dish's parabolic properties to make up for the fewer elements? Or would so few "sticks" compromise the bandwidth beyond usefulness?
Have you done your instructable? I'm having difficulty understanding - could use some pics. Thanks
(can the curve be created with a pencil compass, or the old pencil and string idea?)
Hope this helps any of you. Before I forget, after you finish the project, remember to do a rescan every now and then as some stations my be on-line, but not up to speed. you may pick up a new channel when you do this. GOOD LUCK to you all.
You can then connect it to your TV through a regular coaxial wire!
