Step 5From container to car
I wanted to mention it somewhere and I thought the inserting your electrodes step was already to long, wrap some teflon tape around the teeth that hold the cap on. This will cause LESS HHO to leak out the top. I don't think its possible to completly stop hydrogen from leaking out of a container while allowing easy access to pour more water in.
The water you put in this container needs to have baking soda mixed in. I read that using salt will produce chlorine gas. That seems likley to me as salt is NA CL. Sodium and chloride on their own are deadly to you but combined they sure taste good. In other words don't use it.
-updates-
-I was going to use baking soda origianly but I later read that it lets out solutions that are corossive to aluminum. Chances are your car's engine is made out of it. Furthermore, the chlorine will be coming out of your tail pipe. Who breathes in car emissions that wants to live anyway? The chlorine released is small ammounts too.
And yes I can confirm, through university chemistry knowlede as well as my own personal experience that using salt does indeed produce chlorine (which is mildly corrosive to steel) but ot produces exactly half as much chlorine as it does hydrogen... weigh up your pros and cons
Here's a thought, i wonder if putting one of those tornado things you see everywhere would help mix up the molecules.
http://www.popularmechanics.com/automotive/new_cars/1802932.html
They increase turbulence in the intake, where engine designers have worked very hard to smooth out airflow!
I do agree that those intake turbine systems are useless crap.
Also, this isn't water vapor its separated H2O, so its 2 Hydrogen atoms and one Oxygen atom entering the combustion chamber passively, designed to make the combustion more powerful and efficient, ultimately extending you MPG.
