HIDDEN KITCHEN LID AID
 by iceng
Featured
Step 3: Step 3: Hang it Up .. Left
Attaching the Rod to the Left Top Hinge :
  1.  While you undo the top left Hinge  SUPPORT THE  DOOR  to avoid damaging the bottom Hinge !!
         ( See Second Picture )
  2.  As before, eyeball the length of Rod needed to hang the Lid knob evenly.
  3.  Now make a sharp right angle bend with the Rod pointing into the cavity
  4.  Use the router and metal cutting disc to gouge out a sloping slot in the wood for the Rod to fit under the hinge.
         ( See Pictures )
  5.  Also cut and trim the hook Rod right angle edge about 1/8" long and see it fits well into the slot.
  6.  Then simply tighten the hinge over the Rod.
         ( See Second to Last Picture )
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
