Introduction: How to Build a Guinea Pig Hamster Cage MANSION
Picture of How to Build a Guinea Pig Hamster Cage MANSION
Hello! I would do anything for my little precious 9 year old and her Guinea Pig LUCY. YES, Honestly....I made this the day before I found Instructables <NOT INTENDED FOR HERE> so i can now build her a Treehouse.  Amazingly so, I noticed the PET contest and entered it in immediately! I converted her Barbie 3 story dollhouse into an amazing home for Lucy! Best Part: I found all materials around the house. Didn't purchase a thing! Santa brought the Dollhouse 2 years ago!
Step 1: Supplies & Tools Needed
  1.  Dollhouse NOT used for "primary purpose" anymore (she is done playing dolls)
  2.  Plastic Outdoor/Lawn & Garden Fencing/Netting~I needed 3' x 4' (substitute with anything that works )
  3.  You must measure your dollhouse for accurate dimensions
  4.  Hot Glue Gun & 6- 8 long glue sticks
  5.  Spray Paint (Optional)
  6.  Paper Clips 12-20
  7.  Electric Staple Gun
  8.  Wood 2 inches in height and cut to fit dollhouse dimensions. Razor Knife (easier) or scissors to trim netting
  9.  Your "already available" basic guinea pig or hampster supplies
Step 2: Start With an *No Longer Used for Dolls" Playhouse
Picture of Start With an *No Longer Used for Dolls" Playhouse
Sorry, Did Not Take A "Before" Picture!
Step 3: Spray Paint Basic Lawn & Garden Plastic Fencing Your Choice Color
Picture of Spray Paint Basic Lawn & Garden Plastic Fencing Your Choice Color
Step 4: Use Wood Base-Board to Add Height So Bedding Doesn't Escape and Make Chronic Mess
Picture of Use Wood Base-Board to Add Height So Bedding Doesn't Escape and Make Chronic Mess
Spray Paint Color of Choice, This was just chilling in my paint collection. Cut to fit and I used hot glue to attach to inside of dollhouse.
Step 5: Secure Open Windows in Dollhouse to Avoid Escape
Picture of Secure Open Windows in Dollhouse to Avoid Escape
Hot Glue ~on the inside of the dollhouse windows the plastic netting so your critter can't escape. The purple tube from level 3 descending down to level 2 was purchased at local pet store. This is needed so that Lucy can choose her level to chill on. In addition, there is a elevator on the right side of her home that goes from level 1 to level 2. SHE LOVES RIDING HER ELEVATOR!
Step 6: Secure Entire Front of Dollhouse Opening
Picture of Secure Entire Front of Dollhouse Opening
Use the lawn & garden netting/fencing  to COMPLETLY cover the opening of the dollhouse. I used an DuoFast electric staple gun to attach. The staples are just a few milliliters in size which helps attaching to limited wood areas. Start at one end and stretch to opposite end to insure a tight covering.
Step 7: Carefully Cut Fencing to Create Entrances to Obtain Access to Care for Critter
Picture of Carefully Cut Fencing to Create Entrances to Obtain Access to Care for Critter
Carefully cut doors to be able to get into dollhouse/cage so you will be able to tend to your critter. We used plastic color coated paperclips to be able to close the doors back up. I have a better idea for closing doors but this is working just fine for now!
Step 8: Drill Hole and Attach Water Bottle
Picture of Drill Hole and Attach Water Bottle
jessemonicapearson (author)2015-11-28
your cage is great! The home cages are always the best!
I want to make something like this but with an old dresser or something like that.
Just FYI, The ONLY thing I needed to ad was the running wheel. Guinea pigs shouldn't use them since they are really not made big enough and can cause back problems. Same with the enclosed balls.
Besides that I think your cage is just fine. It is a bit small but I'm sure your daughter has plenty of floor time with Lucy!
SallyC2 (author)2015-05-14
Hi, your dolls house cage is very pretty and a clever idea, but it is way way too small for a guinea pig and also too small for hamsters (especially Syrian). Guinea pigs need large open spaces and are not good at climbing and can not run in wheels. The plastic would be chewed through very quickly and the spray paint is probably toxic. If you want a cheap easy to make cage for a guinea pig make a C&C cage. Bin cages are cheap and easy to make cages for hamster.
Pikachu16 (author)SallyC22015-09-15
It is to small for a guinea pig but not a hamster so I would get your facts straight. Guinea pigs will eat anything and everything they even eat the coraplast on c&c cages so it impossible to keep them from eating bad things. After the spray paint drys your fine so I don't know why you said it's toxic. I'm surprised you didn't comment on how she only has 1 guinea pig because cavys get very lonely.
SallyC10 (author)Pikachu162015-09-15
The RSPCA's minimum size cage guidelines for a Syrian hamster is 100cm by 60cm and that's on one level, extra levels count as additional space, not part of the minimum size.
Yes guinea pigs will eat anything, my 6 are forever trying to eat the coroplast on their cages and I am forever trying to stop them, but coroplast is not toxic! (Though large amounts of it may cause a blockage in their intestines). Toxic substances will kill even if only a small quantity is ingested. Non pet safe paint is not safe even if it is completely dry, if you don't believe me, go any guinea pig forum and ask!
Pikachu16 (author)SallyC102015-09-18
Hamsters don't like to really move but if you put it on a tank like a tank topper you'd be fine. I never said it was but paint and coraplast are just as toxic as each outher because coraplast has a sealant which has the same ingrediants as paint
Dancing Fairy (author)2015-01-18
YASSSS
draya (author)2014-03-02
truly amazing, I adore that there are so many people like me who give their pets a life the deserve!!
One question however, did u use safe spray paint?!? As cute as it is in pink, they WILL ABSOLUTELY chew on it!! Just fyi...
GREAT job!! It's beautiful:) Hope your kiddo enjoys
CookieHamster (author)2014-02-09
OH MY GOSH my hamster would LOVE this!!!! So cute!<3
aqua 12 (author)2013-07-21
Lol my hamster would luv this!!
GummiBear (author)2013-06-09
This makes me (almost) regret I sold my Barbie house. Maybe my Barbie van could be a good home for them?
yeganeh (author)2012-04-16
cool i think we have the same hobby instead i make around 25 floors on my hamster cage between you and me i am only 12 and have been in so many pets inventions i love mKING THINGS FOR PETS DONT YOU V!!!!!!!!!!!!!!!!1
weirdfishes1 (author)2011-12-27
Wow that is cool! Is it a pain to clean though?
markymark134 (author)2011-09-12
Awesome job ! .Good luck on the contest :p
mgosnell (author)2011-09-12
Looks like the GRAND PRIZE to me. Very creative your daughter and hamster must loLOVE the Mansion.Wishing you the best of luck on the contest. P.S. i hope you win :)!
2rainonme (author)mgosnell2011-09-12
Thank YOU SO much! I will get bac with ya on your COOL Gecko! Gotta get back to work. Much Respect
Uptonb (author)2011-09-12
Good luck on the Pets Challenge.
2rainonme (author)Uptonb2011-09-12
Than You So Much! I NEVER imagined to become a finalist. Did not even do it on "purpose"....I love this site! I am VERY excited and just GRATEFUL to be a part of the site! Much Respect! PS......What's taking so long???
By the way i have a gecko cage that i think needs a little more POP to his new enviroment..Maybe you could give me a few pointers or thaughts on how to make my gecko cage awesome like your hamster mansion lol.. Thanks
fegundez1 (author)2011-07-25
excellent job even an elevator id like to see that in action!
2rainonme (author)fegundez12011-07-26
Thanks so much! I'm new here, but VERY willing to take a video of Lucy "loving life" on the elevator. The knob to turn it is on the side (pink) near the water bottle. Be cool if I could add a video to my "already posted" instructable???? Possible?
Kiteman (author)2rainonme2011-09-09
Yes, very possible (I did the same with my bottle-top whistle) - post the video to YouTube, then use the embed code to add it to the Instructable (just click "edit").
2rainonme (author)Kiteman2011-09-09
Alrighty then, although the contest is over now, WOW...I did make it into the Finalists. NEVER expected that! Anyway.....Project for this afternoon! Gotta do it! THX for the kik in the but! Be here soon, Fortunately I have knowledge of "embedded codes" an OLD MySpace thing! LOL.....Have awesome day! MUCH RESPECT "PRO KITEMAN"
ksmith50 (author)2011-08-04
That is a brilliant idea! :D
2rainonme (author)ksmith502011-08-05
Thanks So Much! Yes, My 42 year old Imagination is that of a 5 year old! I'm okay with it though! LOL, Keep's Me Going on those "Overwhelming~Big People" days!
About This Instructable
39,284views
80favorites
License:
Bio: Hello! WOW...I found this site via Google when I decided to build my daughter a Treehouse. The day prior, I created an Awesome Guinea ... More »
More by 2rainonme:How to Build a Guinea Pig Hamster Cage MANSION
Add instructable to:
