HOMEMADE POWER BANK FOR TRAVELLING
2,685
29
5
Posted
Introduction: HOMEMADE POWER BANK FOR TRAVELLING
One day, I went to a forest region in India. I have charger but I am not having a power bank with me. In that forest I stayed in a tree house,there was no plug to charge my mobile. In such situation we can use this type of power bank. It is cheaper than the normal power bank. It can hold the charge up to 7 days. But there is a disadvantage in this power bank i.e it is an use and throw power bank and we can't recharge it.
Step 1: NEEDED MATERIALS
1.Cardboard
2. Aluminum foil
3. Blade
4. Cutter
5. Scissor
6. Non concentrated sulfuric acid
7. Insulating tape
8. Waste mobile charger
9. marker
10.Bowl
Step 2: CUTTING THE CARDBOARD AND THE ALUMINUM FOIL
Place the blade on the cardboard and the aluminum foil and draw the outline of the blade using the marker. Then cut those outline.
Step 3: SOAKING THE CARDBOARD PIECES IN NON CONCENTRATED SULFURIC ACID
Pour the non concentrated sulfuric acid in the a bowl and soak the cardboard pieces for 5 min.
Step 4: BATTERY
Take the blade and pieces of soaked cardboard and aluminum foil. Place the soaked cardboard on the blade and place the aluminum foil on the cardboard,again place the blade on the aluminum foil and place the cardboard and aluminum foil on it. Like that do it for 5 times.At last place a blade alone on the aluminum foil. Combine all those card boards, aluminum foils and the blade by an insulating tape.
Step 5: CONNECTING THE MICRO USB CONNECTOR TO THE BATTERY
Cut the micro USB connector from the waste mobile charger and connect it to the battery.
Step 6: COVERING WITH INSULATING TAPE
cover the remaining parts of the power bank except the micro USB connector with the insulating tape.
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
5 Comments
I have all kinds of questions. How many volts does this put out? What are the amps? Do the number of layers affect the power? Is this only good for one charge? Do you prevent the metal from touching on the different layers?
very good out of the box idea, but, who carries acid to a picnic?
These are pretty helpful, I keep a battery with me whenever we go somewhere. :)
