HOMOPOLAR Motor That Can Be Made at Home
5,569
26
10
Posted
Introduction: HOMOPOLAR Motor That Can Be Made at Home
This is an instructable that will show you to make a motor out of things you have lying around the house
Step 1: Materials
D-battery, Flat magnet, Rod of some sort(I used a screw), Copper wire, Casing(optional), Flat thin piece of plastic(optional), Switch(optional),
Step 2: Assembly
Put the screw on the negative part of the battery. Next you need to put the magnet on the screw head(you see why I use a nail) and finish the circuit by attaching the wire to the positive part of the battery and touch/attach the other end to the magnet
Step 3: Optional
After everything else you may get casing and use a switch that will move the plastic in between the wire and positive section of your battery cutting off your circuit saving energy and making practical use possible (sorry but I have no pictures of this)
Step 4: WARNING
this motor can fly apart if not secured and you'd probably not like a screw in the eye
  • I made it and entere...-davefhunt
    davefhunt made it!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
9 Comments
I also plan to be an engineer I am also starting out but I am 11
I will be a engineer too I am only Twelve though
Thanks I am working on a Radio Controlled car
Hi, i plan on doing this for a physics assessment. My dependent variable would be the angular speed measured by a laser tachometer but for my independent variable i wanted to do voltage but we need at least 7 different sets, so 7 different voltages. I'm not sure how to do this, should i find batteries with 7 different voltages? use a variable power pack? or find another independent variable? thanks.
commas would make this a little more clear.
Just commas you say? What about getting rid of the double negative of, "no way that will never work"? No never means always. What would be proper would be, "no way that will ever work".
i guess you have taken these pictures from madscience.com
i saw this on youtube a couple of years ago and thought "no way that will never work" I was really surprised when i tried it in not only worked but worked really well.
