HOW LOCKET TV CART P3B IS ASSEMBLED
Published
Introduction: HOW LOCKET TV CART P3B IS ASSEMBLED
The LOCKET TV CART P3B has come to the rescue of home owners uncomfortable drilling their walls and are in need of moving their TV’s from place to place. Those with very though lease agreements are also saved. With a unique camera shelf included for conferencing, the LOCKET TV CART P3B is as perfect for offices as it is for homes. The blessing of all these is how simple it is to assemble a LOCKET TV CART P3B. It comprises of a simple six step procedure.
Step 1: ASSEMBLING SUPPORT LEGS
Make sure all four wheels are locked, and then screw all four wheels into support leg of LOCKET TV CART P3B base. You will have to continue by turning the midsection of the base upside down, and then screwing each leg to it.
Step 2: ATTACHING THE POLES
Here you will commence by attaching the support parts which are; the stabilizers, AV shelf rings and the cable guides, to the center pole. After this is done, attach the finishing caps to the top of the poles and insert a safety lock into the lowest available adjustment hole.
Step 3: ATTACHING TV BRACKET AND THE BASE
Attach the TV mount to the poles, with the ridge part facing front. Use appropriate screws, washers and nuts and wrenches in the process; and add the decorative plastic edging to the sides of the mount.
Move on to insert screws into the base and attach with screws and washers through the underside of the base.
Step 4: ADDING SHELF
At this step all you need do is to attach AV tray support bracket to the poles using the necessary screws. Next, use necessary screws to attach the AV tray to AV tray base. This step is complete.
Step 5: INSTALLATION OF CAMERA SHELF
This step has a couple of procedures to follow;
- Firstly, attach the double ring to the poles, and then tighten screws with a hex key
-Secondly, connect the camera and support plate and tighten
-Thirdly, connect the support plate and the kit with the knob.
Step 6: MOUNTING FLAT PANEL TV
Begin by connecting mounting plates to the back of your TV, using appropriate screws and washers depending on your TV. Curved TVs might need extension washers between the mounting panels and TV. Any other TV in which the whole depth is not appropriate for the screw add extension washers to adjust and fit screw.
With all these done a LOCKET TV CART P3B has been successfully assembled, with only six easy steps. Even though it could be a family activity, make sure the children are under strict supervision. Playing with the small parts of the LOCKET TV CART P3B may lead to a choking hazard.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
