A double pole, double throw switch is used for this purpose but you have to wire it up correctly to reverse the polarity going to the linear actuator.
Remove these ads by
Signing UpStep 1: Required materials
-DPDT rocker switch
-insulated disconnect terminals (female) x 6
-wire
-wire cutter/crimper/stripper tool
-a linear actuator or DC motor to control
Visit Our Store »
Go Pro Today »
Thanks!
Thanks!
thanks
though the basic diag too is well undrstood
"...I've got two switches such as the microswitch on the special switches section from this page http://www.kpsec.freeuk.com/components/switch.htm. they're setup one facing the other with a lever in between both, the thing is that when none of them are depressed the motor runs and by depressing either one of them it stops. Thanks in advance for your advice."
If this is what you are meaning to have, this diagram may help.. you need to have a diode on each micro switch between the Common and Normally Closed. When the micro switch is depressed it will cut the voltage to the motor, when you reverse polarity to change direction of the motor the voltage can't flow through the micro switch because it's cut the circuit, which is why you need the diode (basically.. a one-way gate for electricity). So when you reverse polarity the voltage will be able to go through the diode and move the motor off the micro switch.
www.firgelliauto.com/images/actuator-with-two-limit-switches.jpg
If this isn't what you're doing, let us know and I'm sure someone here can help sort it out..
I'd be careful using two SPDT switches instead of one DPDT, in some scenarios if the mechanical link fails, switching only one of the two micro-switches could give you a dead-short!
That said, I'd take a look at the diagrams again and make sure your wiring matches. Basically, you want the motor to be powered off the "COM" or Common poles of the switch. Then run power to the NC and NO posts, making sure that you reverse polarity when you hook it up to one set.
Maybe post a basic diagram of how you've got yours wired? I'd love to help, I just need more input!
Also, just out of curiosity, what're you making?
Alternatively, you could have a second set (this time with just 1 switch for each axis) that's just on/off, and you'd pass either positive or negative through the switch.
Hope that helps.
