3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
HOW TO: Wire a DPDT rocker switch for reversing polarity
Step 2Connecting the wires to the disconnect terminals
First you need to cut a bit off each wire that will be going to the motor. This is the jumper that will allow the polarity to swap.
I'm using blue and brown wire. THE COLOR OF THE WIRE IS NOT SIGNIFICANT. You can use red and black, or any combination of wire color. Because you'll be swapping the polarity back and forth on the actuator, the color of the wire, and whether they are on the right side or the left doesn't matter.
Twist together one end of the blue jumper wire and the end of the main blue wire. Then push this into the disconnect terminal and crimp with the wire tool.
Do the same for the brown wire.
At the end of the blue jumper attach another disconnect terminal.
Attach the main blue terminal to one of the poles on the side, attach the main brown termainl to the pole right next to it.
Attach the blue jumper connector to the opposite corner, and the brown jumper to the other corner to form an 'X' across the switch.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:Troy (Firgelli Automations)
