3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
HOW TO: Wire a DPDT rocker switch for reversing polarity
Step 5UPDATE: Wiring Diagram
I've had a number of people ask me about a wiring diagram, as the photos may not be enough on their own.
Troy
http://www.FirgelliAuto.com
18 comments
Mar 16, 2010. 7:18 AMwhizzlord says:
 Hi! i want to use a micro switch to reverse the polarity on the dc motor instead of using a dpdt rocker switch. please advice me on what to do. a circuit diagram will be highly appreciated.
Thanks!
Jul 2, 2007. 12:59 AMdepartment_g33k says:
Troy, I think your wiring diagram is either lacking "COM/NC/NO" labels, or is reversed. I've used this scheme myself many times, and that diagram looks like the NC and COM terminals are backward. The one I've used is: Supply (+) to NC(a) and NO(b) Supply (-) to NO(a) and NC(b) Actuator (+) to COM(a), and finally, Actuator (-) to COM(b). Thanks for posting!
Feb 5, 2010. 12:39 AMkapluf says:
PS.: I was intending for the motor to be stopped or off whenever the lever is in the center position and for the lever to make it go clock or counter-clockwise depending on which is depressed, like a remote control for a rc car.
Feb 5, 2010. 12:37 AMkapluf says:
I realize your comment was made year and a half ago, however I have a problem with your diagram and it would be nice if you could help me solve it. The problem is that I've got two switches such as the microswitch on the special switches section from this page http://www.kpsec.freeuk.com/components/switch.htm. they're setup one facing the other with a lever in between both, the thing is that when none of them are depressed the motor runs and by depressing either one of them it stops. Thanks in advance for your advice.
Nov 17, 2009. 6:57 AMmankhandelwal says:
thanx to d labeled circuit diagram fom::::department_g33k
though the basic diag too is well undrstood
Jul 2, 2007. 1:29 AMdepartment_g33k says:
(removed by author or community request)
Aug 11, 2008. 7:14 PMdepartment_g33k says:
Feb 5, 2010. 8:03 AMdepartment_g33k says:
 Troy, after looking again, you're right.  Most I've seen have the markings, but I see what you're saying.  Thanks for the excellent post!
Feb 5, 2010. 12:44 AMkapluf says:
I would really appreciate if you could help me with the problem I explained to department_g33k, thank you!
"...I've got two switches such as the microswitch on the special switches section from this page http://www.kpsec.freeuk.com/components/switch.htm. they're setup one facing the other with a lever in between both, the thing is that when none of them are depressed the motor runs and by depressing either one of them it stops. Thanks in advance for your advice."
Feb 5, 2010. 8:02 AMdepartment_g33k says:
 Kapluf, I'd love to help, but I'm going to need more input on how you've got your switches wired.  The URL you provided shows a basic SPDT, which is essentially half of the switch described in this post.
I'd be careful using two SPDT switches instead of one DPDT, in some scenarios if the mechanical link fails, switching only one of the two micro-switches could give you a dead-short!
That said, I'd take a look at the diagrams again and make sure your wiring matches.  Basically, you want the motor to be powered off the "COM" or Common poles of the switch.  Then run power to the NC and NO posts, making sure that you reverse polarity when you hook it up to one set.
Maybe post a basic diagram of how you've got yours wired?  I'd love to help, I just need more input!
Also, just out of curiosity, what're you making?
Feb 5, 2010. 12:27 PMkapluf says:
Hello to all and thank you very much for your quick answers. I am building a remote controlled car as a small w-e project, even though it is not wireless yet. I actually have everything wired and installed and am working on the conroller which is a dual action two levers, one for gonig forwards-backwards and one for the steering (they're both plain and simple 9-12v dc motors with two NiCd 6v 1000mA batteries set up in series for the 12v needed, no servo since it is very hard to get where I live). I've got four switches (two for each lever). I inicially tried department_g33k's wiring diagram and what happened is that both motors would stay on when neither of the switches was depressed. Whenever I depress either of them it would stop the motor for that particular set. I haven't tried Troy's diagram but I can see that the effect is going to be similar if not the same. I am about to try a new setup I came up with a friend of mine and I'll tell you about it when I'm done. I'll try to upload a few pictures when I get home so you can see what I'm talking about. Thanks again for your help!!
Feb 5, 2010. 1:26 PMdepartment_g33k says:
The one caveat of using SPST switches (NC/NO/COM) vs. Troy's diagram is that you don't have on/off control, just direction.  Troy's diagram, using switches that have a middle (off) position allows full control.
Alternatively, you could have a second set (this time with just 1 switch for each axis) that's just on/off, and you'd pass either positive or negative through the switch.
Hope that helps.
Feb 5, 2010. 4:51 PMkapluf says:
Well, I'm back home and I just finished making some research.... It turns out that my 2 switches setup isn't going to do the trick. The thing is that the switch mentioned by troy stays in the position you select and I need it to go back to OFF position when I release it, so first thing in the morning, I'm going to the hardware shop and get some proper switches and redo the controller... I can't thank you guys enough you've been most helpful!!
Feb 5, 2010. 5:10 PMdepartment_g33k says:
 My pleasure, glad the instructables community was able to help!  When you're finished, you should create an instructable with your project!!
Feb 9, 2010. 7:57 PMkapluf says:
Just so if anyone is interessed in something like this, I solved the problem by making two arrays of two spdt switches per lever, from which I removed the NC contact, therefore making them spst and it made it so much easier!!
Feb 5, 2010. 5:52 PMkapluf says:
I'll do that as soon as I finish the project, what I CAN do now however, is to recommend this small program that helped me design my diagrams pretty quickly and easily, it's called circuit maker 6 student edition, it's a freeware (even though it is not backed up in any way by the maker anymore), and it can be easily found on google, and one last time thanks to department_g33k and troy for all their help whitout which I couldn't have come to my conclusions this fast!!
Mar 20, 2008. 3:33 PMpeterdepue says:
Troy, great diagram for the switches I purchased at my local hardware store. Took me 30 mins to wire up two motors. They work great. Thanks for the posting
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:Troy (Firgelli Automations)
