HOW TO FIND OUT WHICH WIRE HAS POWER IN a USB CABLE
Published
Introduction: HOW TO FIND OUT WHICH WIRE HAS POWER IN a USB CABLE
About: English is not my first language. I use Google Translator and patience of friends to write Instructables. Feel free to point out style, syntax or grammatical errors. Actually I work in TECHSHOP Menlo Park C...
I checked it out @ Techshop
Quick answer: RED and BLACK
Step 1: First, You Will Need to Find an Used USB Cable, a Multimeter and a X-acto Blade.
(You can't see but the red and black wires are already peeled, may be someone tried before me to extract power from this cable)
Step 2: Then You Need to Peel the Wires
Step 3: Connect Your USB Cable to a Computer
Step 4: With the Multimeter Start to Hunt for Which Pair of Wires Measures Around 5V.
Step 5: It Is ... the BLACK and RED Pair
Step 6: Now Go Find a USB Female Port
Step 7: Cannibalize the Circuit
Step 8: Take Out the Plug
Fit the female plug into your power source
(the USB cable has 4 wires, and in this case the 2 outside wires were the power ones)
Step 9: Weld and Isolate Everything Together
Step 10: And Done :) This Was Done at Techshop
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    3 Comments
    what we can do with the remaining wire the white and the blue wire
    That are DATA+ and DATA- wire... Simply nothing. Only if you know what are you doing.
    Good idea! Thank you for the information.
