How to Fix a Zipper (without Replacing It)
Introduction: How to Fix a Zipper (without Replacing It)
Fix It Contest
First Prize in the
Fix It Contest
This is a easy way to fix a zipper without replacing it. This method is really fast too. It works when the zipper pull doesn't close the zipper together anymore. I don't really like to replace zippers, because they always come out a little bit wavy when I do it myself.
You can save a jacket, a tent, a sleeping bag, and many other items.
Step 1: What You'll Need
You will only need a pair of pliers.
But if the zipper pull is really destroyed or is made of plastic you will need a NEW ONE OF THE SAME SIZE. YOU CAN FIND IT IN ANOTHER OLD JACKET. Or you can buy one online for really cheap.
Step 2: Remove Stopper
Remove the little iron stopper of the top of the zipper, which will be on the same side of the jacket where the zipper puller is.
(Sometimes they are made of plastic, so it is little more difficult to remove and replace. You may need to substitute it with few knot of thread or something else. There is many tutorial out there on how to replace a stopper).
Step 3: Remove Zipper Pull
Remove zipper pull. You can probably see that it is all distorted.
Step 4: Adjust the Zipper Pull
With the pliers close the two sides of the zipper pull, try to make it look like the original shape again.
If your zipper pull is not too worn out you can try to close it directly on the zipper, without removing it.
(if it is made out of plastic, if it is too bent or if it breaks doing this, you need to find another one of the same size, they are available online, or you can take it from another old zipper).
Step 5: Put Back the Zipper Pull
Put back the zipper pull. It may take a little bit of time...
Step 6: Put Back the Tooth
Put back the iron tooth with the pliers.
Step 7: Done!
Faster than changing it!
  • Paper Contest 2018
    Paper Contest 2018
  • Science of Cooking
    Science of Cooking
  • Pro Tips Challenge
    Pro Tips Challenge
Thank You!
You just save my money.
You know, you can squeeze the zipper slider without taking it off the jacket. If the slider is broken, you can replace just the slider with a new one the same method as above. The small metal piece at the top is a stopper, not teeth.
Yes, I wrote it already in step 4, but sometimes, when it is really distorted, it is better to remove it, to take a better look of it, and adjust the right and left hole equally.
And thanks for the word "stopper", I'll change it.
Right you are! Except it's a Top Stop that is removed.
So much bad advice on zippers out there it's crazy
Pinching only works in some cases and is temporary since these are pot metal and not iron, really you don't have to take the slider off to pinch. What you want is a new slider. You can find a great repair kit for replacing zipper sliders at
Great customer service and such a useful product!
OMG this is sooo useful! I recently had a zipper issue with some motorcycle gear...took me hours to figure out. this will help next time.
On man what a timely Instructable! Best backpack ever developed that zipper issue. Read this..... 4 minutes later... Success! Thanks man. You solved that with alacrity.... and grace! Well done.
alacrity? Does your mother know you are using that kind of smut in public? (Thanks for the word!)
Thank you! I'm happy it was so useful to many people
