loading
Step 5: PUT BACK THE ZIPPER PULL
Put back the zipper pull. It may take a little bit of time...
Thanks Brother!! ;)
<p>You are welcome!</p>
If I have no pliers what I do
<p>perhaps you buy a pair they are dirty cheap</p>
<p>i bought a pair @ DOLLAR TREE :^)</p>
Uh, get some? You can't expect to fix many things without basic tools. Pliers are about as basic as it gets. You can find them everywhere for a couple of bucks.
<p>You buy pliers or use your teeth and trust your luck...</p><p>Pliers are useful !</p>
I've lost and ripped the bottom starter off my Barbour coat and nike hoody its ripped at bottom of the teeth at the side nr starter to how to fix thanks
Good.
<p>Brilliant!!! Works like a charm :)</p>
<p>If the teeth are broken the whole zipper needs to be changed. If the slider (the part that opens or closes the zipper) is hard to move up and down on a metal zipper, use some graphite on the zipper teeth and it will slide easily. Don't know what would work on a plastic zipper .</p>
<p>If a plastic zipper (with teeth or with coils) is having issues moving up and down you can use a silicon spray or something called Super Slick Stuff. It smells like oranges while the silicon just smells bad.</p>
<p>or candle-grease</p>
I have a zipper issue, maybe someone can help? The starter piece at the bottom fell off, you know the little tab that slides into the zipper pull to get started? Fell right off ? It's on a hoody I like, but I can't zip it! Thanks for any help.
<p>If you lost the part you might be able ti fix the zipper using superglue to buildup a new starter-tab...?</p><p>Or glue-on some plastic to form a tab..... ? </p>
<p>You can squeeze the zipper pull right on the garment with a pair of needle nose pliers, just gently squeeze it and try it, if the zippers closes and locks the teeth your good to go but, you can squeeze too hard and if you do just use a small screwdriver and open it up just a skosh, ya just have ta toy with it. Lube it with silicone spray for a smooth operation. Well, Happy DIY'in! Yom Tov!</p>
<p>What you did was fine. There is a missing tooth in the picture and the zipper won't work very well this way. Sooo how do you handle that?</p>
Thanks, I will definitely be trying this one. I have a couple zippers that needed replaced and its hard to find a shop close that still does it. Fingers crossed it works for me ?
<p>So good ,simple and important </p>
I have a zipper problem on my bag. The slider is still attached to one side of the track, but I can't get it back on to both. Would this method work? (It's a rather pricey bag and I'd prefer to not ruin it)
If this method won't work, because it's a captive zipper, you can try bending the slider like the picture shows. However, don't bend it much, because the metal is very brittle and might break. But if you're careful, it could work,and it's worth a try.<br>Then make sure the zipper sides are lined up, squeeze the slider back over the teeth, and slide it back and forth to rezip it.<br>Then, take some of the stuff out of that overstuffed bag!
<p>God bless you, it worked! for those without pliers, try using your teeth, it's what I did, but be careful not to hurt yourself!</p><p>My favorite jacked it back! YES! GOD BLESS!</p>
Pliers are cheaper than dental work. Metal pieces can easily chip your teeth. Be smart...
<p>Thanks for the tip! And for the bless too!</p>
<p>What if it's the kind of zipper that doesn't separate at both ends, like a sleeping bag or a pullover sweater or the zipper on your pants?</p>
<p>Seems like an easy fix to a common problem. I may have to try this on a couple of items of mine. Thanks for the simple fix.</p>
<p>Thanks a lot, worked perfectly on my jacket!!!</p>
i fixed my zip<br>thx :)
You can buy a zipper repair kit in the notions at your local fabric store and even at some walmarts
<p>Saved me 80 dollars. l didn't realize it was this easy, thank you!</p>
<p>Works great,</p><p>Thanks for the instructables.</p>
<p>You are welcome.</p>
<p>got it thanks saved a jacket </p><p>I found the part on Amazon, zipper kit.</p><p><a href="http://amzn.to/1SE67qE" rel="nofollow">http://amzn.to/1SE67qE</a></p>
<p>Happy to know that, and thanks for the link</p>
<p>so i bought a walls suit something like a carhart and used it 3 Times and the zipper broke along with some teeth how can i repair this with out paying another 70 bucks for a suit</p>
<p>If some teeth broke to, you can't use this method&hellip;I think you may have to replace the whole zipper, but I'm not sure...</p>
Yea i was thinking that is it an expensive fix?
<p>Don't know there, but in Italy I bring a jacket to the tailor to change the zipper and it was about 15 euro (16$) with the replacement zipper included.</p>
<p>I have a jacket that, if I don't make sure the starting piece is all the way in, will come unzipped. Right now I can't get the zipper pulled down to separate the right and left sides. I've tried aligning the teeth better, but I am not getting anywhere. Any suggestions?</p>
<p>May be try to remove the zipper from the top ( step 2 and 3), than adjust the zipper pull, or replace it, put it back in and see if than it will work&hellip;but I'm not sure, just a thought...</p>
<p>OH MAN, I lost the stopper tooth! I heavily whip stitched the area where the tooth was to create a thread stopper. Worked perfect otherwise, thanks!</p>
<p>You are welcome! Sorry about the stopper... the thread is a good idea for a replacement.</p>
<p>Nice! Worked perfectly for the zipper on my leather jacket. Thank you!</p>
<p>You are welcome, hHappy it worked!</p>
<p>God bless you, it worked! for those without pliers, try using your teeth, it's what I did, but be careful not to hurt yourself!</p><p>My favorite jacked it back! YES! GOD BLESS</p>
About This Instructable
1,351,600views
535favorites
License:
More by marcellahella:RICE MILK RING NECKLACE RUSTC APPLE AND RICOTTA PIE
Add instructable to:
