HOW TO MAKE a LETTER W OUT OF PVC PIPE
CraftArt by
442
Posted
Introduction: HOW TO MAKE a LETTER W OUT OF PVC PIPE
Are you bored? Do you have extra PVC pipe laying around?
Here is a simple project to make a letter W out of PVC and connectors!
Step 1: Materials
ALL PVC PIPES AND CONNECTORS USED ARE A HALF INCH.
You will need...
15 in of PVC
3 90 degree elbow connectors
Marker
Ruler
Pipe Cutter
Step 2: MEASURE & CUT
Use the ruler and measure out each piece of PVC. Use the marker and mark the length of the piece needed. Then use the pipe cutter to cut each piece.
Step 3: 4 Pieces
You should cut two pieces of 4 in PVC, and two pieces of 3 in PVC.
Step 4: Left Side
Take one 4 in PVC and one 90 degree elbow connector and connect them together.
Step 5: RIght Side
Repeat the step from the left side and do it for the right side. (Take one 4 in PVC and one 90 degree elbow connector and connect them together.)
Step 6: Middle
Take the last 90 degree elbow connector and attach both 3 in pieces of PVC into both sides of the open connector.
Step 7: 3 Pieces
You should now have 3 pieces. The left side, The right side and the middle. Lay them out together in the shape of a W.
Step 8: CONNECT
Now take the left side and attach the connector to the 3 in pipe. Do the same with the right side.
Step 9: FINISHED!
There you have it, a letter W made completely out of PVC pipe and connectors!
ENJOY!
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
