HOW TO MAKE a NEW FOLDER IN NOTEPAD
Published
Introduction: HOW TO MAKE a NEW FOLDER IN NOTEPAD
About: im klaus and i am a computer nutcase ohh and im single HINT HINT
HII TOODAY I AM GOING TO SHOW YOU HOW TO MAKE A NEW FOLDER IN NOTEPAD
all you need for this is notepad and some basic batch file skills
Step 1: New Folder
its a very simple code
after the md bit on the second line of the comand is the name you can change it to whatever name you
like but dont change eanythink ells
md is the comand for a new folder
the code is on the next step copy it into notepad
Step 2: The Code
the code is below
@echo off
md new
start new
Step 3: Saving It
make shure you save it as a _______ . bat file
exp. newfolder.bat
. bat must go at the end of evry batch file
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    9 Comments
    how convert again new folder
    thanks for the idea. well it help much to those people who still used manual adding of new folders - - right..?
    Mine even adds contents to the folder!
    (But I`m still working on it after 12 minutes!)
    Isn't it easier to type "md (folder name)" in the command prompt? L
    yep it would be but some people like to do it the hard way aswell but thanks for pointing that out
    just about any way would be easier than this
    . Nice iBle, but, as L points out, it's a rather 'round-about (Yes rules!) way of doing things. But that's not necessarily a bad thing. Other points: 1) Notepad is not creating the directory. It won't even run the batch file. 2) No explanation of how to run the batch file. 3) Spelling/punctuation/capitalization is atrocious. If English is not your primary language, ask for help. 4) Get rid of all-caps. That's considered shouting on the 'Net. . . It's not a bad iBle, it just needs some work. If you need help, just ask.
    thanks very much for your help its my first time making a batch file so I will take all this into consideration
