HOW TO MAKE a ROTATING LAMP SHADE
Published
Introduction: HOW TO MAKE a ROTATING LAMP SHADE
Things You'll Need
Bottle of soft drink 2 liters (preferably transparent or colorless)
An incandescent lamp with socket ( the base of a lamp)
Wire
Super glue
Aluminum can
Needle
Vellum
Cardstock
A basis for making the top of the luminaire
Step 1: Second Step
Cut the soda bottle, using elastic and stylus to help cut the shape of a cylinder
Step 2: Third Step
Take the base to make the top of the lamp (most important part) is what will make the lamp rotate , crop each picture to make a hollow base
Step 3: Fourth Step
Paste a cycle of aluminum (aluminum can) and give a "mixed". His appearance resembling the "hood of a car"
Step 4: Fifth Step
Gluing the aluminum base to the cylinder
Step 5: Sixth Step
To support the luminary use wire. Warp wrapped the wire lamp (as a base) and lift the wire to create a slightly taller tip the lamp, where you'll put the needle (to make the luminaire movement smoother)
Now attach the base of the cylinder to the lamp
Step 6: Seventh Step
You can embellish (decorate) the cylinder out with the parchment paper, cardboard and glue down the tube
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
