POCKET-SIZED SPIN THE BOTTLE
1,198
6
6
Published
Introduction: POCKET-SIZED SPIN THE BOTTLE
this is how to make an easy and cheap way to make a SPIN THE BOTTLE
THE ACTUAL SIZE OF MINE IS 2 INCHES and 6/10 of an INCH.
Step 1: MATERIALS YOU WILL NEED:
  • HEAVY SCREW
  • 2 HEAVY BOLT NUTS
  • SCISORS
  • LARGE SOLDERING TIP
  • TAPE
Step 2: STEP 1
GET 1 OF THESE IN YOU LOCAL STORE (usually in the front) and have toys inside.
THEN MAKE A CENTERED HOLE IN THE CAP AND BOTTOM OF IT.
Step 3: STEP 2
INSERT THE THICK AND HEAVY SCREW INTO THE CENTER OF THE CAP. IT WILL HELP IT BALANCE.
Step 4: STEP 3
PUT THE 2 HEAVY SCREW IN THE INSIDE OF THE CAP REALLY TIGH, FOR BETTER BALENCE. IF IT IS NOT TIGHT, TRY PUTING THICK STRIPS OF A BUSINES CARD AND SOME TAPE OR SUPER GLUE.
Step 5: STEP 4
GET THE BOTTOM PART OF THE TINGY AND THEN THE SOLDERING TIP, AND SCREW THEM TOGATHER.
Step 6: STEP 5
NOW GRAB THE LOWER AND BOTTOM PART AND PUT THEM TOGATHER.
THE ACTUAL SIZE OF MINE IS: 2 INCHES and 6/10 OF AN INCH
    • Water Contest
      Water Contest
    • Backpack Challenge
      Backpack Challenge
    • Clocks Contest
      Clocks Contest
    6 Discussions
    I took this pocket-size spin the bottle to a partie last night and every one like it. THANKS!!!
    dude, I like this. it really helps to not carry around a huge bottle. THIS IS AMAZING!!! how did you ever come up with such a grate idea?? IT'S POCKET- SIZED!!!
    It's a great concept and a fun quick project. The only criticism I have for it is that it seems to be a bit dangerous to put in your pocket with the sharp point. what I would suggest to solve this problem is to attach the soldering tip to the yellow cap then glue anther cap to the other side, so that the point could be flipped to the other side concealing it in the plastic.
