HOW TO MAKE a WATER TANK ALARM
6,660
10
Published
Introduction: HOW TO MAKE a WATER TANK ALARM
Connect all negative terminals of leds with each other like shown in the image and connect the resistor also.
Step 1:
Step 2:
Connect the negative end of the battery with the resistor.
Step 3:
Connect a wire with the possitive end of the battery connector and leave the wire touching in the bottom of the tank so that the circuit will become complete.
Step 4:
plzz vote.
    • Casting Contest
      Casting Contest
    • Stick It! Contest
      Stick It! Contest
    • Oil Contest
      Oil Contest
    2 Comments
    or.... you only consider the light indicator panel....
    or... you're hopping to get full voltage/current through the water to lit the led's?
    I think you should explain a little better what is your purpose! Just to clarify please!
    Thank you!
    I am not certain what this monitors, what the circuit looks like, or what kind of sensor it uses to give an alarm. What is this? How do I use it? What does it do for me? Why do I need it? How have people done what this does until now? Thank you.
