Introduction: HOW TO MAKE CONCRETE FOOTING FOR GARAGE,DECK,POSTS,CAR PORT,CANOPY,PORCH,H-ANCHORS FOUNDATION
Today foundations for a wood garage are to be made. Some have already been completed but some are still missing, and in this video, I want to briefly show how we make them. We use these H-anchors, which must be set into concrete. These are for 120mm wooden beams, they make them in other sizes too. Keep in mind that the anchor itself does not ensure a rigid connection between the foundation and the beams. In this case, however, a garage with walls is being built and these walls provide a connection between the wood studs for an adequate stiffening of the building. The size of the foundation can be found in the construction statics papers. For this dual garage statics were created. If the position of the foundation is calibrated, we can start to dig the hole. We use a spade and a shovel. You can also use a hole spade or hand excavators. But in this case its boggy topsoil and we use the spade to loosen the compressed peaty soil and the shovel to get the material out of the hole. With two people that works very quick. The 35 x 35 cm hole was dug out in about 10 minutes. At a depth of approximately 1,2 meters we reached load bearing soil. Now the hole can be filled with concrete and compacted. In some areas the ground level differs from the desired height of the foundation, here we use an upturned bucket with a cutout bottom to get to the desired height. We use pre-cast concrete with a strength class of C25 / 30 and a 0-8mm grain. In order to achieve the desired strength, a layer wise compaction with the hand tamper is very important. So that the anchor is placed exactly in the right place, I have stretched a cord and marked the center of the anchor with a black dot. Now the anchor has to be aligned with the level. If it is properly seated, the concrete can be filled up to the top and compacted. The floor of the garage will be layed with pavers later. I make sure that the foundation is not in the way of the pavers later. That way the foundation disappears later under the paving. Now only the concrete has to harden and the garage can be placed. If the sun shines strong and drying out the concrete before the chemical hardening process is complete, the concrete can be watered from time to time and covered for example with fabric. I wait a few days before I build the garage. The concrete is relatively hard after 24 hours, however, the hardening process is completed after 28 days. The bucket can now be taken off and reused if needed. As you can see the H-anchors are sitting nice and tight in the concrete. I hope this video helped you. I would love a thumb und and you are welcome to just leave a comment for questions or ideas. Visit my channel for more helpful landscaping videos. don't forget to subscribe!
My how-to-videos are free to watch for all viewers. Creating my videos means a high technical, financial and temporal demand for me. If you are sharing, liking or subscribing my videos, i appreciate it! If you want to support my work, helping thousands of people to save time and money, you can make a donation over paypal (CarlTheLandscapeGuy@gmail.com) Many thanks to all supporters. Your Carl the landscape guy.
ringai (author)2015-08-28
Just an FYI, if the piers were already poured and you need to retrofit an anchor, a couple companies make post/column supports with a stand-off base that fasten to the pier using a threaded stud you epoxy into holes drilled in the pier. Simpson StrongTies and another brand whose name escapes me, both make a post/column support that's IBC approved for high wind resistance.
Simpson's model is ABU44.
Great instructable.
About This Instructable
3,687views
72favorites
Bio: Hi i am Carl and i am a landscape guy, thank you for droping by at my channel! I studied landscape construction and have been ... More »
More by CarlTheLandscapeGuy:HOW TO BUILD ROUND PAVER BRICK PATIO | LAY TWO COLOR CLINKER STONES | INDIVIDUAL TERRACEHOW TO FIX LOW SPOT IN DRIVEWAY+REPAIR PIPE |BLOCK PAVERS REMOVE+LAY COMPACT SAND BED JOINTS INSTALLHOW TO MAKE CONCRETE FOOTING FOR GARAGE,DECK,POSTS,CAR PORT,CANOPY,PORCH,H-ANCHORS FOUNDATION
Add instructable to:
