Introduction: HOW TO MAKE STRAWBERRY MARGARITA JELL-O SHOTS
Picture of HOW TO MAKE STRAWBERRY MARGARITA JELL-O SHOTS
Learn how to make these amazing strawberry margarita Jell-O shots! Perfect for a New Years Eve party or any get together for that matter.
https://youtu.be/4IuYgQ9ky10
Step 1: To Do a STRAWBERRY MARGARITA JELL-O SHOTS You Need!!!
Picture of To Do a STRAWBERRY MARGARITA JELL-O SHOTS You Need!!!
You will need: Strawberry Jello, water, sugar, strawberries.
- Balance it at the point where it is widest, parallel to the cutting board, to cut off the top.
- Then cut off a tiny part of the tip so that strawberry can stand upright.
- Then take a melon baller or small measuring spoon and carefully scoop out the inside.
Step 2: A Bit Time Consuming But Oh So Worth It!
Picture of A Bit Time Consuming But Oh So Worth It!
- Combine Jell-O mix with 3/4 cup boiling water and stir 2 minutes to completely dissolve.
- Pour Jell-O into strawberry cups.
- Fill them up as much as possible, because Jell-O shrinks when it solidifies.
- Wet the side of the solidified Jell-O shot with water and roll in sugary.
Step 3: If You Like This Episode, Check Them Out and Remember to Subscribe!!!
Picture of  If You Like This Episode, Check Them Out and Remember to Subscribe!!!
dp176406 (author)2016-01-10
A good shortcut for hollowing out the strawberries is to use a power drill with a bit that is 1/2" or larger.
MORENA DIY (author)2016-01-09
:))) Thank you!!!!!
DIY Hacks and How Tos (author)2016-01-09
Great idea. I have used strawberries to serve small amounts of ice cream before, but I never thought of jello.
About This Instructable
1,805views
47favorites
License:
More by MORENA DIY:3 Awesome Life Hacks / Stationery Knife IdeasDIY Stress Phone Case / SMARTPHONE LIFE HACKS3 Awesome Life Hacks with Drinking Straws
Add instructable to:
