HOW TO MAKE a DIY GLOW STICK!
4,130
53
Posted
Introduction: HOW TO MAKE a DIY GLOW STICK!
This projects is an easy way to make a DIY non toxic glow stick!
WHAT YOU NEED-
RGB auto colour changing led,
Pen,
9 volt battery clip and battery,
Solder and soldering iron,
Rotary Tool OR Hack saw and sand paper,
470k Resistor.
Step 1: Cutting and Sanding
First you need to cut the top of the pen off,
Then give it a light sanding to smooth out the edges.
Step 2: Soldering the Led and Resistor!
Place the led in the top of the pen and it should fit snug!
Then solder the resistor to the longer lid and a black wire to the shorter leg.
Step 3:
Now the resistor should be soldered to the red lead of the clip,
And the black should be soldered to the black lead of the clip.
Step 4:
Lastly glue the glow stick to the clip,
And connect the battery and...
'"WOW"
IT WORKS GREAT!
Go to jackshow2s.weebly.com for more!
Step 5:
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    3 Comments
    To turn it off simply un clip the battery:)
    How do you turn it on and off ?
    I like that you used the barrel of a pen. Looks great!
