HOW TO REDUCE AND PREVENT HAIR MATTING AND TANGLING IN THE NAPE AREA
Published
Introduction: HOW TO REDUCE AND PREVENT HAIR MATTING AND TANGLING IN THE NAPE AREA
About: Passionate about beauty, wigs and hair extensions. Always seeking great ways to provide and help others with their journey. Our website offers quality wig making supplies for individual consumers and compa...
Have you ever been recently inquisitive about the most convenient way to merely reduce or possibly prohibit hair from instantly matting and tangling in the nape area?
A considerable number of "Fashionistas" have desired to discover the solution to this challenge. As a result, we released an overview of simple steps you can make to fix your problem!
Step 1: TAKE OUT THE WIG COMBS
Numerous wigs are available with wig combs in the nape section. They are primarily inserted for stability, nevertheless, most of the locks in the nape area end up being ensnared in the attached combs.
Adjust your wig by eliminating the combs then making use of a wig gripper or possibly adjustable straps to always keep your wig in position.
Step 2: MAKE USE OF STYLING TOOLS SPECIFICALLY MADE FOR WIGS
A plastic or rubber comb is going to accumulate negative charges on the surface area and then cause static in the hair. Take advantage of a styling comb as well as a brush which is specifically made for wigs.
In the event that a plastic brush or comb is utilized, moderately mist the item with an antistatic agent comparable to Static Guard before styling to provide a shield to keep away the static.
Step 3: FINGER COMB OR DETANGLE YOUR LOCKS ALL THROUGH THE DAY
Lengthy tresses have a tendency to bunch up around the nape area whenever dressed in necklaces as well as bulky collars.
Finger comb and even detangle all of your hair regularly during the course of the day to moderate hair collecting in the troubled area.
Step 4: CASUALLY SPRAY HAIR WITH WATER & FABRIC SOFTENER
Artificial wigs are inclined to lose some design and style whenever the strands generate static electricity and cling.
Fabric material softener consists of formulations that contain a positive charge that typically result in a balance between the positive and negative ions.
Artificial hair doesn't possess actual moisture like natural hair, therefore it is extremely dry. Fabric softener plays the role of a convenient and effective conditioning agent.
  1. Use 2 parts fabric softener with 2 parts cool water.
  2. Add the water with the softener into a sprayer bottle then blend thoroughly.
  3. Spritz the wig with the concoction and then allow the unit to air dry entirely before styling.
Step 5: STAY CLEAR OF HIGH TEMPERATURES
Refrain from subjecting your current wig to intense exposure to heat. Pay careful attention while around very hot ovens, stoves or even barbecue grills.
The fibers of manufactured wigs will be completely deteriorated because the high temperature would certainly singe the hair fibers.
On top of that, steer clear of significant amounts of sunlight in addition to a heated neck (sweating excessively).
Step 6: DRESS IN DELICATE, SOFT GLIDING CLOTHING
Smooth clothing materials enable the tresses to move smoothly and naturally without static, friction or snags.
Step 7: UTILIZE a DRYER SHEET
Just simply wipe a fabric sheet along the nape area to get rid of static cling.
Step 8: INCLUDE EXTRA WEFTS TO THE NAPE SECTION
Integrating another weft to the lower part of the nape area is going to weigh the hair down. As a result, it will constrain unnecessary movements across the back.
Step 9: APPLY LIGHT OIL
Flip your hair to lightly blend oil into your strands.
The application of oil is normally not suggested for artificial fibers, however, we've found that a lightweight Moroccan oil or even Shea Moisture Edge Treatment is quite effective!
Step 10: DETANGLE HAIRSTYLE COMPLETELY AFTER THE END OF THE DAY
Free your hairstyle of all tangles before settling after the end of the day. It most certainly is recommended that your wig is detached ever night.
Alternatively, in cases where you are not able to do this, detangle your hair, gather it up into a very high clip or bun and then sleep on a satin pillow case.
Step 11: BOBBY PINS ARE INCREDIBLY USEFUL
Last but not least, bobby pins are very useful.
This easy little technique is going to significantly lessen the tangling and the matting and EVEN EXTEND the life-span of your hair and extensions.
  1. Lift the hair in your nape area
  2. Part away a 1/2 inch across the lowest part of the nape
  3. Raise the parted section and pin it up in to the loose hair
Along with preventing the matted hair, it will surely establish volume along with a light bounce to any hairdo.
If you have found this information be useful, feel free to share!
To find out more about our company and products, please visit us at www.AmidBeauty.com.
Join our mailing list to receive tips and techniques for wigs and hair extensions.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
