HOW TO REMOVE PRINTS WITHOUT DAMAGING THE TAPE ON THE BED
Published
Introduction: HOW TO REMOVE PRINTS WITHOUT DAMAGING THE TAPE ON THE BED
About: I like to build, solder, invent stuff ,make and designee pcb's, and program.
in this instructables  i will show you how to remove prints from your 3d printer without scraping , cutting,or damaging the tape you put on the bed. i thought of this because i always ruin the tape that i put on my heated bed and then if i don,t replace it for the next print the next print might mess up.soo i thought of ways to remove it and i thought it has to be easy small and thin to fit under the print and i thought floss.
you will need
  • floss
  • a finished print
  • a 3d printer
1st string the floss around the bottom of your print.
2nd start working your way around the print i found that it helps to do this in a sawing motion going back and forth.
3rd when the floss comes all the way threw you can now lift your print off the bed.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    3 Comments
    Does mint flavoring act as a lubricant? :) This is a great idea!!
    Great idea!
    I was using a razor blade, and often messing up the tape as well.
    I will give it a try!
