HOW TO TIE a ELDREDGE KNOT
Published
Introduction: HOW TO TIE a ELDREDGE KNOT
This how you tie one of the fanciest knots of all! the Eldredge Knot!
Step 1:
Start with the wide end of the tie on the left side of your body and the small end on the right side. The tip of the wide end should rest at the top of your belt buckle.
Step 2:
Small end over the wide end to the left
Step 3:
Under the wide end and to the right.
Step 4:
Up to the center, towards neck loop.
Step 5:
Through the neck loop and to the left.
Step 6:
Across the front, to the right. Then up into the neck loop from underneath.
Step 7:
Down to the left and around the back of the wide end to the right. Keep this part loose.
Step 8:
Bring it across the front towards the left and through the loop made in the previous step.
Step 9:
Pull the small end towards the left to tighten.
Step 10:
Up to the center, towards neck loop. Down through the neck loop and to the left.
Step 11:
Up to the center, towards neck loop. Down through the neck loop and to the right. Keep this part loose.
Step 12:
Across the front towards the left and through the loop made in the previous step.
Step 13:
Step 14:
Tuck the rest of the small end behind neck loop on the left side.
Step 15:
You're Done!
Step 16:
    • Stick It! Contest
      Stick It! Contest
    • Woodworking Contest
      Woodworking Contest
    • Pets Challenge
      Pets Challenge
    That's a really neat knot! It looks awesome :)
