HOW TO UPGRADE LAPTOP RAM FROM 2GB TO 6 GB
4,526
23
Posted in TechnologyLaptops
Introduction: HOW TO UPGRADE LAPTOP RAM FROM 2GB TO 6 GB
HELLO MY FRIENDS
MY NAME IS WAQAR ALAM.
TODAY I'LL SHOW YOU HOW TO UPGRADE YOUR LAPTOP RAM AT HOME
WHY?
BECAUSE OF SPEED & WORKING OF SOFTWARE LIKE PREMIER PRO,ANDROID STUDIO ETC....
i have hp laptop with 2 gb of ram but when i try to run android studio pc crashed every time
after lot of research i found out why ....just because of lower ram of my pc
so ,
here is the step by step procedure to upgrade or increase your laptop ram
i have also made a video on youtube for this topic you can check that out....above....
Step 1: POWER OFF YOUR LAPTOP & FLIP UPSIDE DOWN
BY DOING THIS YOU CAN SEE YOUR LAPTOP BATTERY
Step 2: JUST REMOVE THE LAPTOP BATTERY
SEE YOUR LAPTOP MANUAL FOR DOING THAT
FOR ME THERE IS BUTTON TO SLIDE FOR REMOVING BATTERY
Step 3: GET a SMALL STAR SCREWDRIVER
JUST UNSCREW THE SCREW AFTER REMOVING BATTERY
AS SHOWN IN THE ABOVE IMAGE
IF YOU DON'T HAVE SCREWDRIVER DON'T WORRY YOU CAN BUY FROM HERE OR ANYONE ELSE .....
http://www.amazon.in/SD-Enterprises-100-Original-M...
Step 4: POP UP THE PANEL THAT YOU UNSCREW
MAKE SURE YOU DON'T BREAK THE LAPTOP PART WHILE DOING THAT
AFTER REMOVING COVER YOU CAN SEE THE RAM INSTALLED IN YOUR LAPTOP
AS SHOWN IN THE FIRST IMAGE
THERE IS ALSO 1 SLOT FREE FOR UPGRADES
WE WILL USE THAT TO INCREASE OUR RAM
Step 5: CHECK YOUR COMPATIBLE RAM & BUY ONE
I WILL HELP YOU TO FIND WHICH RAM IS COMPATIBLE WITH YOUR LAPTOP
JUST FOLLOW THE LINK BELOW
http://www.crucial.com/usa/en/memory-info?cm_re=to...
PUT YOUR LAPTOP MODEL NO.. IN SEARCH OPTION
JUST BUY THAT RAM FROM THAT WEBSITE OR ANY OTHER WEBSITE BUT MAKE SURE YOU BUY THE CORRECT MATCH AS SHOWN IN THE SEARCH RESULT
Step 6: INSTALLING RAM IN THE SLOT
STEP ONE:FIND THE CORRECT ORIENTATION
STEP TWO: INSERT RAM INSIDE SLOT SLIGHTLY AND TRY TO PUSH DOWNWARD IF IT GOING THEN
STEP THREE : PUSH IT DOWNWARD UNTIL YOU HEAR THE POP SOUND
Step 7: COVER THE BACK PANEL AND TIGHT IT WITH THE SCREW
JUST INSERT THE PROTECTIVE FILM
THEN COVER BACK THE BACK PANEL WITH SCREW
Step 8: POWER ON YOUR PC
JUST INSERT THE LAPTOP BATTERY AND PUSH THE POWER BUTTON
WAIT UNTIL LAPTOP START IT MAY TAKE UP TO 5 MINUTE TO START FOR THE FIRST TIME
NOW PRESS ALT+CTRL+DEL TO START TASK MANAGER
THERE YOU CAN SEE BOTH THE SLOTS ARE IN USE AND WORKING AS SHOWN IN THE
2ND IMAGE
THANKS FOR READING..........
MAKE SURE YOU SUBSCRIBE
+++++COMMENT BELOW FOR ANY QUESTIONS++++++
Step 9:
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    2 Comments
    You had an existing ram of 2gb and entered a 4gb with it? Shouldn't
    they be equaled...2 x 2? My notebook has a limit of 4gb, what does
    your manual say for your laptop? Most laptops start with 2gb could only
    go up to 4gb..Correct me if i am wrong.
    Yes,
    4+2=6gb
    Most of laptops have 2 slots
    not 2+2 it depends on the motherboard of pc....
    For the correct configuration for your motherboard
    Follow the link of
    crucial ram website mentioned in above steps....
    I'm using this for months without any problem
