3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
HOW TO build cheap VHS tape WINDBELT generator
Micro windbelt generator is the cheapest and easiest DIY project for generation of wind energy. Even with its limited output capacity, small wind-belt can be used in situations where other wind generators would normally give no useful power output.
Especially while camping or sailing, windbelt generator can recharge your batteries, cell phone, ipod, radio, small LEDs and
much more. Micro windbelt is made using the parts worth less than 5$, which makes this windmill extremely cost effective!
Price can be even lower in case you have an old VHS video tape, small magnet and transformer coil nearby.
First of all, I have gathered all necessary parts for micro wind generator. An old VHS videotape which will be used as a membrane, two small neodymium magnets taken from refrigerator -magnet souvenirs or from PC HDD, and finally coils - (see Picture below, it is from washing machine controller motor). You need to fix the magnet(s) onto a (VHS) tape using glue. When a magnet moves in and out of a coil of wire(or near it), electrical current flows through the wire, and therefore windbelt generates electricity.
Shape of my magnet is not ideal, thus I will try to get smaller and round-shape magnet which could get in and out of coil.
The Key Advantages of Windbelt over existing micro-wind turbine technology is the fact that it is good at taking power from turbulent wind flows, i.e. in a built up domestic setting, and it is also very quiet in operation.
Unlike PV solar panels, wind turbine generators do not scale down so well. While large wind turbines can generate huge quantities of electricity very efficiently and relatively cheaply, as the size of the wind turbine is reduced, efficiency reduces and cost per generated watt jumps quite enormously.
more details on: http://solar.freeonplate.com/windbelt_windgenerator_DIY.htm
Cheers,
5 comments
Mar 6, 2012. 8:08 PMmikenaly says:
I realize that this is a bit of an older post, but having just found it, I thought I would add a few thoughts. Based on the apparent construction and operation of this windbelt generator, if you could get your smaller round magnets and additional coils, you could increase your output easily. You stated 1.7V os your measured output. If this is using the project as pictured in your instructable, if you could add an additional 8 coils and magnets and wire them in a series/parallel combination so that you had a series of 3 parallel circuits, I believe you could get close to a 5V output with a usable enough current to create a fairly decent supply for most of today's standard 3V to 5V devices. Just a thoght, but worth looking into. Might try it myself if I can come up with the materials.
Oct 16, 2011. 1:25 AMlemonie says:
I don't see how the tape moves (enough) with that magnet sat on it. Also, the diagram shows 2 coils and the tape not resting on either.
Are these pictures of something finished, like Kiteman asks: what does that produce as output?
L
Oct 16, 2011. 3:26 AMlemonie says:
You got volts, that's a start.
Show us how it develops, I'm interested.
L
Oct 15, 2011. 11:07 AMKiteman says:
What sort of output did you get?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Mladen_solar
