Thanks everyone for making this a popular instructable! It's been a few years since I've posted it, so by way of an update I'll answer a couple questions here. 1. The purpose of the hot plate is to keep the rice at a temperature at which it will sprout. If it's warm out, you don't need the hot plate. Recently I built a warming box powered by a simple light bulb attached to a temperature sensor; I put the pot of rice in there and it works great. Easier but a bit more expensive than the hot plate. 2. You can also sprout rice as you would alfalfa sprouts--soak, and then rinse and turn the jar upside down over a strainer. Personally, I find it easier to sprout when the rice is in water. 3. Green tea works to reduce the presence of bad bacteria that cause spoiling. Recently, though, I have had more luck using whey or other fermenter starters. Anyone experimented with this?
Sprouted brown rice can also be called sprouted brown rice, GABA brown rice (for the amino acid GABA that is created during the sprouting), or hatsuga genmai in Japanese.
On page one is a short history and some health benefits. Skip to page two to get straight to the how-to.
Remove these ads by
Signing UpStep 1: History of GBR
Why not just buy a machine? GBR is made by soaking brown rice in warm water for up to three days. The rice machines that claim to have a GBR setting soak for two to three hours. Although this probably has some health benefit, most people seem to agree that it's not long enough to properly germinate the rice. Why don't they make the cycle longer? The water gets stinky ... we'll deal with that later.
The rice is also sold by many companies around Japan now. I might go into the business too--it looks like they're making silly profits! They're charging 1000 to 2500 yen for a kilo of rice! One-cup versions on sale in America are about $3 a serving, also pretty expensive.
Visit Our Store »
Go Pro Today »
(I'm developing a modern nomadic lifestyle that is independent of society).
No need to waste energy keeping the concoction warm for 3 days.
http://radishboy.blogspot.com/2008/05/sprouted-brown-rice.html
If you cant get to the site here's the method:
1. Rinse 1 1/2 cups (or more if desired) brown rice several times until the water is clear.
2. Place the rice in a bowl and cover well with filtered water.
3. Let stand 12 hours or overnight.
4. Pour rice into a strainer and rinse well.
5. Set the strainer over a bowl to drain out of direct sunlight. Cover with a clean dishtowel.
6. Every 12 hours, rinse the rice well.
7. After 24 to 48 hours, small sprouts will appear. Use or refrigerate the rice until ready to use.
8. Cook as you would cook unsprouted brown rice, using slightly less water (for the 1 1/2 cups of rice in this recipe, use 2 cups water). The cooking time will also be shorter.
http://www.sciencedaily.com/releases/2008/07/080728192817.htm
http://www.sciencedaily.com/releases/2008/09/080922155950.htm
http://www.sciencedaily.com/releases/2007/05/070509161030.htm
First I obtained a heating element from local thrift store. Both an electric frying pan and a fondu pot gave nice temperature readings after adjusting their thermostats to around 101 +- 2 deg F. I did spend some time using an accurate thermometer to find where to set the thermostat (that came with each pot). I decided on the fondu pot for aesthetic reasons.
I filled the fondue pot with water and put a rubber pot holder in the bottom of the pot. I then put a 4 cup glass measuring cup into the water filled fondu pot creating a double boiler (the glass cup does rest on the rubber pot holder at the bottom of the pot). I prefer to germinate the rice in the glass measuring cup as the fondue pot is aluminum. Filling the fondue pot with water acts as a buffer so that the rice inside the glass measuring cup (inside the water filled fondu pot) never gets too hot or too cold (around 101 deg F). The rice loves to be coddled this way and germinates like crazy. You will see tiny tiny whiteish sprouts at the end of your grains in 24 hours or less. I soaked the rice in strong green tea, rinsing every 12 hours. After this then cook the rice.
Green tea seems to be an essential part of this process. I did not get stinky water. One day when a short cut was taken and I used really weak green tea, the rice became so stinky I was afraid to eat it because of bacterial over growth. Not getting this problem when soaking with strongly steeped green tea.
I notice enhanced mental clarity and significantly less fatigue at the end of the day (but I did also go off of all gluten grains). I will be doing this for the rest of my life. It is an inexpensive way to feel fantastic.
I think the water still needs to be changed. Maybe I should have rinsed the rice first....
