Difficulty: 3 out of 10
virtually no experience in computer or soldering is needed.
WARNING!
If you fallow these steps and something goes array i am in no way responsible, but i will try to help if you have any problems :)
YOU WILL BREAK WARRANTY IF YOU FALLOW THIS INSTRUCTABLE
If you are not gentle and careful you might damage the internals of your machine farther.
GROUND YOURSELF BEFORE TOUCHING ANY OF THE INTERNAL PARTS! (place your hand on a large metal object, you only need to touch it for a few seconds)
Before you start you should be sure this really is the problem your laptop is having. HERE is a link to HP's site, try to see if you can still get your machine professionally fixed for free, better fix.
Basically if you have the fallowing problem this is for you: machine wont start after pressing power button, all lights will come on and HDD will spin and fan will start, but it shuts down after a few seconds and keeps doing this over and over, also no video on computer.
I know these model laptops also have a bad wifi problem, but this tut will not solve that.
Remove these ads by
Signing UpStep 1Tools/disassembly
- Small flat blade screw driver (for prying)
- Small Phillips screw driver (for unscrewing, and then later screwing :)
- HEX 5.0 MM nutdriver (two 5mm nuts need to be removed. can probably be replaced with needle nose plier)
- Bare light bulb (heat source. I used a lamp)
SUPPLIES:
-Thermal paste
- A clean new penny
DISASSEMBLY:
I am not going to cover disassembly here, its far too long, but i will link HP's pdf and upload the pdf in case HP takes down their archive
There is no need to take the screen apart, just remove from bottom part of casing
I would suggest placing all the parts in a cardboard box for safe keeping.
In the PDF go all the way down to the "Removal and replacement procedures" section for information on completely disassembling the notebook.
c01095493.pdf(595x792) 3 MB| « Previous Step | Download PDFView All Steps | Next Step » |
ive read about that issue, gonna try this and see if i get it fixed
