HP Prime Programming Tutorial: Displaying Results
Published
Introduction: HP Prime Programming Tutorial: Displaying Results
About: I love the inspiring minds of the instructables community Here are some links to some inspiring people: Jude Pullen: http://www.judepullen.com/designmodelling/ Austin Kleon: http://austinkleon.com/
This instruction isn't intended to be a primary location of learning to program the HP Prime. These are a few things I've spent hours learning and just want to share so another novice programmer can get up and running faster. The 600+ page manual offered by HP does a good job clarifying syntax and how to get started in programming.
For now, I'm just covering how to display program results.
Step 1: Displaying Results
Depending on what you want to display, there are several options.
  • Display a single number (47)
  • Display a single number and text (A=47)
  • Display multiple numbers (47, 13)
  • Display multiple numbers and text (A=47 and B=13)
And another influence is do you want to do more calculations with them?
Once you add text to your program results, you are no longer allowed to do calculations. I prefer not using text because I can't do further calculations with the result (unless I type it on the home screen myself).
When trying to display two or more numbers in a result and still do calculations, I use a matrix or a list.
Here are various syntax examples, (let A and B represent program variables and A=47 and B = 13)
Step 2: ​Displaying: Example 1
RETURN A;
// This will return a value to the home screen, which can be used in future calculations
Step 3: Displaying: Example 2
RETURN "The answer is "+A;
// this returns a string, no further calculations can be done with result, only viewing.
Step 4: Displaying: Example 3
RETURN "A value is " + A + " B value is" + B;
// displays a string, only viewing is allowed, no further calculations can be done.
Step 5: Displaying: Example 4
M1(1) refers to matrix one and the first element in the matrix.
M1(2) refers to matrix one and the second element in the matrix.
RETURN M1;
Matrixs allow the display of multiple numbers from a program's results as well as allowing you to do further as seen in the pic.
In order to use a matrix, you must go to the matrix list on the HP Prime, and select M1(our matrix of choice), then choose it to be a vector.
For more information on Matrixs, refer to the HP User Guide
Step 6: Displaying: Example 5
L1(1) refers to List 1 and it's first element.
L1(2) refers to List 1 and it's second element.
RETURN L1;
Lists allow the display of multiple numbers from a program's results as well as allowing you to do further as seen in the pic.
For more information on Lists, refer to the HP User Guide
Step 7: Displaying Numbers in Decimal Form
To get you program to return decimal values, use
RETURN approx(A);
the approx will approximate the variable A giving you a decimal answer.
Or, you can run the program from the CAS home, then press the button left of the delete button.
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    Nice! Thanks for sharing.
