Introduction: HTPC Streacom ZF240 Power Supply Mod
THIS MOD CAN BE USED ONLY WITH 35W INTEL CPU!!!
Streacom has made a wonderfull power supply but it has 2 major flaws
http://www.streacom.com/news-item/zf240-product-an...
Spec Before Mod
Power Output: 240W Combined, 3.3V @ 10A, 5V @ 10A, 5VSB @ 2A, 12V @14A, -12V @ 0.3A
Input Power: 100-240V AC 50/60Hz
Output Connectors: 1 x 20+4 ATX, 1 x 4PIN CPU, 2 x SATA, 2 x MOLEX, 1 x FDD
Spec After Mod
Input Power: 100-240V AC 50/60Hz Output
Connectors: 1 x 20 ATX, 1 x 4 PIN CPU, 1 x 6 PIN GPU, 2 x SATA
1. There is no 6 pix connector for Graphic Card (Nvidia GTX 960 has a 120W GPU) and if an adapter is used both connectors will end up using same 12V wire which is unable to provide enough current.
The solution is to remove 4 pin connector from 20 + 4 pin connector and use 12V line from it to carry power to GPU together with existing 12V wire from MOLEX (we sacrifice also 2 unused MOLEX connectors)
Step 1: PSU After Rework
2. Cable management is bad.
As soon as PSU is installed in the computer case all wires spread.
Solution.
Rework cable management as final image by grouping wires.
This mod was used in
https://www.instructables.com/id/Silent-Steambox-Ga...
allowing GFX upgrade to Gainward Nvidia GTX 960
http://www.gainward.com/main/vgapro.php?id=960&lan...
!! MOD IS NOT INTENDED TO BE USED WITH OC MODELS WHICH CAN REACH 140W !!
