HUMAN and OBJECT Following Arduino Robot
1,954
13
Posted in TechnologyArduino
Introduction: HUMAN and OBJECT Following Arduino Robot
About: GUYS FOLLOW US AT OUR FB PAGE ..DO LIKE ND SHARE ..OUR YOUTUBE CHANNEL IS S_R TRONICS...WATCH..TRY..INNOVATE..TASTE THE SUCCESS..THANK U..
hello guys...
we have made a new nice project...object following robot thats based on arduino...
this robot is made by using a ultrasonic sensor....
ultrasonic sensor:-
An Ultrasonic sensor is a device that can measure the distance to an object by using sound waves. It measures distance by sending out a sound wave at a specific frequency and listening for that sound wave to bounce back.
so..this sensor can find object with range and follow or avoid a object and human in specific distance..
so lets start...
Step 1: Components
Step 2: Circuit Diagram
here is the simple circuit diagram........
trig pin is connected to arduino 2pin
echo pin is connected to arduino 3pin
motordriver l293d have 16pin...
1,8,9,16pin of l293d is connected to +5v
4,5,10 and 11 pin of l293d is connected to gnd
so..
2pin of l293d is connect to 4pin of arduino
7pin of arduino is connect to 5pin of arduino
9pin of arduino is connect to 6pin of arduino
15pin of arduino is connect to 7pin of arduino
motor1 is connected to 3 and 6pin of l293d
motor2 is connected to 10 and 14 pin of l293d
that it....then connect to power supply....
Step 3: How This Robot Works??
this robot is works depend on ultrasonic sensor,which is help to find any object in range...
ultrasonic sensor works in 180degree angle...
so if distance of ultrasonic sensor 25cm or <25
this time robot moves forward using two dc gear motor...
else ..if distance <25..this time robots can moves backward..
if(distance>=25)
digitalWrite(m11,HIGH);
digitalWrite(m11,LOW);
delay(400);
else
delay(400);
if(distance>=40)
delay(500);}
if distance is 40cm or >40..then robots will be stop..
Step 4: Uploading Code
plz copy the code below and paste it in your arduino..
#define trigpin 2
#define echopin 3
int m11=4;
int m12=5;
int m21=6;
int m22=7;
void setup()
pinMode(m11,OUTPUT);
pinMode(m12,OUTPUT);
pinMode(m21,OUTPUT);
pinMode(m22,OUTPUT);
pinMode(trigpin,OUTPUT);
pinMode(echopin,INPUT);
void loop()
int duration,distance;
digitalWrite(trigpin,HIGH);
delayMicroseconds(1000);
digitalWrite(trigpin,LOW);
duration=pulseIn(echopin,HIGH);
distance=(duration/2)/29.1;
if(distance>=40)
delay(500);
else
if(distance>=25)
delay(400);
else
delay(400);
Step 5: Result
guys ...plz watch this video..
how this project or robot works???.....
plz see this this video till end for best result...and subscribe our channel and share also...
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    How do you make this formula distance=(duration/2)/29.1?
