HY502B RFID Module for PcDuino
1,513
19
Posted in TechnologySensors
Introduction: HY502B RFID Module for PcDuino
HY502B is a 14.3 Mhz Near Field RFID module.
For more details you please refer to http://linksprite.com/wiki/index.php5?title=RFID_Reader/Write_Module_B_(SPI_interface)
HY502B use SPI to communication with host. pcDuino provide the SPI API, so that we can use HY502B with pcDuino.
Step 1: Connection Diagram
1.  J1-1 (SCL)  of  HY502B -> D13 of pcDuino
2.  J1-2 (MISO) of  HY502B -> D12 of pcDuino
3.  J1-3 (MOSI) of HY502B -> D11 of pcDuino
4.  J1-4 (NSS) of HY502B -> D10 of pcDuino
5.  J-17 (SIG)  of HY502B -> D9 of pcDuino
Certainly, HY502B’s VCC and GND should be connected to pcDuino
We use a 1602 LCD with I2C interface to display the result.
The connection between LCD and pcDuino is as below:
1.  J1-1(SDA) —> SDA of pcDuino
 2. J1-1(SCL) —>  SCL of pcDuino
Some, LCD’s VCC and GND should be connected to pcDuino.
After connected, power on the pcDuino, we can see the LCD backlight is on, but there is no character display.
Step 2: Get Arduino API for PcDuino
We will use github to get Arduino API for pcDuino.
If your pcDuino do not install git before, we need install it first.
$sudo apt-get install git
Then, we use git to get Arduino API for pcDuino
ubuntu@ubuntu:~$ git clone http://www.github.com/pcduino/c_enviroment
Step 3: Code
HY502B ‘s read code
#include "core.h"
#include "Wire.h"
#include "LiquidCrystal.h"
#include "string.h"
#define uchar unsigned char
#define uint unsigned int
LiquidCrystal lcd(0);
//SPI Bus state definitions
#define SPI_RDY 0xF0 // ready
#define spibusy 0xaa // busy
#define spiread 0xbb // write
#define spiwrite 0xcc // read
#define SCL_0 digitalWrite(13,LOW)
#define SCL_1 digitalWrite(13,HIGH)
#define MISO digitalRead(12)
#define MOSI_0 digitalWrite(11,LOW)
#define MOSI_1 digitalWrite(11,HIGH)
#define NSS_0 digitalWrite(10,LOW)
#define NSS_1 digitalWrite(10,HIGH)
#define SIG digitalRead(9)
#define SUCCESS 0
#define FAILURE 1
uchar g_cReceBuf[10];
uchar ComPWRdwn[] = {0x02, 0x03};
uchar ComAutoSearchCard[] = {0x03, 0x13, 0x01};
uchar ComGetCardSn[] = {0x02, 0x20};
uchar ComHaltCard[] = {0x02, 0x12};
void port_init()
pinMode(13,OUTPUT);
pinMode(12,INPUT);
pinMode(11,OUTPUT);
pinMode(10,OUTPUT);
pinMode(9,INPUT);
unsigned char SPIRWByte(unsigned char cSendByte)
unsigned char i = 8;
unsigned char cRecByte;
while (i--)
cRecByte *= 2;
SCL_0;
delayMicroseconds(2);
if((cSendByte & 0x80)==0x80) MOSI_1;
else MOSI_0;
cSendByte *= 2;
cRecByte |= (unsigned char)(MISO);
SCL_1;
SCL_1;
return cRecByte;
unsigned char spi_cStatus(void)
unsigned char cStatus;
NSS_0;
cStatus=SPIRWByte(spibusy);
cStatus=SPIRWByte(0xFF);
NSS_1;
return cStatus;
unsigned char SPI_Read(unsigned char *cP)
unsigned char cCnt,cStatus;
unsigned char cCheckSum = 0;
for (cCnt=0; cCnt<100; cCnt++)
cStatus=spi_cStatus();
if(cStatus==0xF0)
cCnt=253;
delay(10);
if(cCnt==254)
NSS_0;
cCnt=SPIRWByte(spiread);
cP[0]=0x01;
for (cCnt=0; cCnt<cP[0]; cCnt++)
cP[cCnt] = SPIRWByte(0xFF);
cCheckSum ^= cP[cCnt];
if(cP[0]>32)
NSS_1;
return FAILURE;
NSS_1;
if (cCheckSum == cP[cCnt])
return SUCCESS;
return FAILURE;
unsigned char SPI_Write(unsigned char *cP)
unsigned char i,cStatus;
NSS_0;
cStatus=SPIRWByte(spiwrite);
for(i=0; i<cP[0]; i++)
cCheckSum ^= cP[i];
cStatus=SPIRWByte(cP[i]);
cStatus=SPIRWByte(cCheckSum);
NSS_1;
return cStatus;
void setup()
lcd.begin(16, 2);
lcd.clear();
lcd.print("read card id:");
lcd.setBacklight(HIGH);
port_init();
void loop()
uchar cStatus,i;
uchar *cPa;
while (1)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print("no card,waiting.");
if(SIG==LOW)
delay(100);
cPa = ComGetCardSn;
SPI_Write(cPa);
delay(100);
cStatus = SPI_Read(g_cReceBuf);
//SPI_Write(ComHaltCard);
lcd.setCursor(0,1);
lcd.print("card ID:");
for(i=2;i<6;i++)
lcd.print(g_cReceBuf[i],HEX);
while(!SIG) ;
You can download the code here: HY502B
Step 4:
Modify \test\Makefile:
LIBS=-L../../sample/core -larduino -lspi
INCS=-I../../sample/core/include
TARGET=../../sample/test
OBJS = io_test adc_test pwm_test spi_test adxl345_test HY502B
all: $(OBJS)
@mkdir -p $(TARGET)
@mv $(OBJS) $(TARGET)
io_test: io_test.c
$(CC) $(LIBS) $(INCS) < -o $@
HY502B: HY502B.c
adc_test: adc_test.c
pwm_test: pwm_test.c
spi_test: spi_test.c
adxl345_test: adxl345_test.c
$(CC) < -o $@
clean:
@for i in $(OBJS); do rm -f $(TARGET)/$$i; done
HY502B: HY502B.c is the new added
Open Terminal and compile the library
ubuntu@ubuntu:~$ cd c_enviroment
ubuntu@ubuntu:~/c_enviroment $ make
Step 5: Run
input ”$./HY502B” under test folder
Support Fourm:
http://www.pcduino.com/forum
http://linksprite.invisionzone.com
Support mail: support@linksprite.com
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
