3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hack The Spy Ear and Learn to Reverse Engineer a Circuit
This instructable introduces the venerable Spy Ear in details and my way to reverse engineer a circuit.
Why does this device deserves its own instructable?:
-You can buy a Spy Ear for a dollar!
-It can amplify sounds up to 60 dB or a factor of a 1000.
-It has a self limiting property and adjusts the gain so that the amplified signal volume is always just right.
-It runs of two LR44 1.5 volt button cell alkaline battery, so it's perfect for portable projects.
-Many of today's projects, such as in robotics, require analogue front end for sensing the environment and the Spy Ear circuit is just right to fill in as a multi-purpose front end amplifier.
-It is simple enough to reverse engineer.
-I am making another instructable using this device.
So the Spy Ear is a fantastic cheap,small and rugged circuit for modding and hacking
Check out my other Instructables:
MAKE A HIGH VOLTAGE SUPPLY IN 5 MINUTES
Super Easy E-mail Encryption Using Gmail, Firefox and Windows
Make a Voltage Controlled Resistor and Use It
Make a Ball Mill in 5 Minutes
Make a Rechargeable Dual Voltage Power Supply for Electronic Projects
SODA CAN HYDROGEN GENERATOR
Step 1How to Reverse Engineer a Circuit
This step shows you how to reverse engineer the circuit.
1. First take a picture of the front and back of the circuit.
2. Trace the pcb layout on the back using a graphic program like photoshop. Try using the "bucket fill" tool first. if that doesn't work color it by hand.
Don't color the whole pcb layout. Leave the areas where a solder is made clear, so that you can figure out which component's leg goes where.
3.Copy the pcb layout you made and paste it on top of the device's front picture. Flip it horizontally and adjust the scale and position so that the trace is super-imposed exactly on top of the components (see picture below).
4.Then comparing the different pictures and looking at the actual circuit, draw in the components' symbols from node to node. (see last picture).
5. Next, you'd need a circuit drawing program to rearrange the rough circuit that you drew by hand (see next step).
Count the components. Use the count as a checksum when you reconstruct the schematic. It is easy to forget something.
123 comments
1-40 of 123next »
Jan 5, 2012. 4:39 PMachraf52 says:
Do I really need that transistor or use any type .
Jan 6, 2012. 5:57 AMachraf52 says:
Great you helped me from having to buy those type as I have so much ones but no one is this type, now I only have to grab capacitors and resistors and put them together .
Oct 10, 2011. 9:48 PMstatic says:
Back in the day, and even in the modern era I simply shine a pen light from the solder side through to the component side, to aid in tracing out the circuit. There are time when you will need a stronger light though, and that fatigues the eyes quickly, even young eyes. Nice idea here, but bucket fill generally gives me fits. I have learned to use [control]+S often.
Mar 13, 2011. 9:16 AMDave54321 says:
Wow that's great, here is another diagram of the Spy Ear from area 50
it allows you modify the Spy ear by removing a transistor and powering
it by the computer to make a super duper sensitive Condenser Mic
which worked well for me as I wanted a better mic than I could find at
radio shack.
here is the link to several directional Mic's the last one is the Spy Ear
http://www.techlib.com/area_50/PTM/audio.htm#super and also includes
the schematics.
also the .1 uf caps don't appear to be electrolitics so observe the DC potential
in this circuit when using electolitic caps by putting the + to the higher potential
so they don't blow up, which I doubt at that low voltage.
Apr 5, 2011. 4:36 AMDave54321 says:
I think you mean AGC automatic gain control. I don't know how the
photo resistorwould work in that circuit.
What lead me to the spy ear was I wanted to make my computer
mic actually put out some audio to make a series of affermation
statements to play while I sleep under my pillow. The little condenser
mic's that are powered by the computer audio circuit board lack
sensativity so you must speak closely to the mic and you pick
up a lot of unwanted noises made by the mouth that are not normally
heard in conversation.
What is the title of you other Instructable ?
Apr 4, 2011. 8:30 AMburdockwing says:
i have noooo idea what you are talking about its literally like you're talking gibberish
Mar 14, 2011. 7:49 AMtechh2 says:
why this circuit dosent work please send me explication for this circuit plz plz i ned this circuit
Jan 22, 2011. 9:23 PMVaxinius says:
Im trying to open your schematic in LTSpice and all I get is a bunch of text grid locations in a list. Need a bit of help with this. Bit new to this program but im familiar with programs like it. When i download the file it saves as a .tmp? Should that happen?
Jan 25, 2011. 1:05 PMVaxinius says:
nope even when i rename the file i still get a spice error message that says theres "multiple instances of [symattr]"
then it lists a whole bunch of text of wire locations etc. same thing as before.
your help is appreciated as im a training electronics technician in the canadian forces and getting the edge on software like this can only do me good.
Jan 25, 2011. 5:45 PMVaxinius says:
Aha.
Turns out my problem was i didn't know how to properly rename an extension. Kept renaming the file the whole time. ...to the sandbox!
Aha.
Aug 24, 2010. 3:43 PMmulluysavage says:
I'm trying to pair spy ears circuits with appropriate speakers. Do we know what a well-matched speaker would be? I know that under-powering speakers are a good way to damage them. I'm seeing .2 watt, 2 watt, 5 watt speakers out there.
Jun 29, 2010. 1:11 PMthelandlord says:
Just bumping this to let UK readers know "Poundland" has been selling these units for the last couple of weeks - I'm sure there must be a lot of ways to re-purpose these...
Sep 21, 2009. 2:38 AMdeltasoft says:
Please visit here: http://www.deltasoft.com.cn/english
That is a good software of pcb reverse engineering
That is too easy for pcb reverse engineering.
Dec 19, 2009. 5:10 AMfkuk says:
can you wire this up to a lm3916 vu meter?
Nov 18, 2009. 4:19 AMyuvensius Edulgensiano says:
so, which one the true..? i dont understand about these.
Sep 30, 2009. 4:08 AMskandar says:
merci +ok
Apr 15, 2009. 1:10 PMlewis94 says:
do anyone know where i can get a spy ear in the uk (shops/stores) coz i really want to give this a go but cnt get a spy ear and i not old enough to buy online so if anyone could help that would be fab lewis94 :D
Jul 20, 2009. 8:03 AMiectyx3c says:
eBay UK has it.
You do not need a credit card to buy online.
You can pay by Postal Order from your local Royal Mail Post Office.
Here is a link:
http://preview.tinyurl.com/lfl4o4
Jul 17, 2009. 10:48 PMnamzer0 says:
there's something fishy about the schematics and the PCB Picture. They Don't Match!!! Please fix. I can't find where the 47uF capacitor is. in the schematic
May 20, 2009. 8:59 PMthing 2 says:
Where do I get it? (i live in usa)
Jul 8, 2009. 1:56 PMraykholo says:
i believe that toys r us sells spy toys including this one, check online i also think u can just build the circuit yourself according to the schematic in this instructable and an online order from an electronics shop (digikey, allelectronics, the goldmine are some of my faves)...
Jun 21, 2009. 11:20 AMsk8er6 says:
I just want to make a pocket headphone amp for cheap, so could i just solder wires from a headphone jack to where the mic used to be? thanks
Jan 3, 2009. 2:14 PMGrzegorz says:
Try to use layers in Photoshop. What I am doing is taking the pictures of bottom and top then flip the bottom one and cover the top PCB picture with flipped bottom as different layer. Then you can set brightness and transparencies of layers (each one separately) for the best result. Even if they aren't exact same size you can stretch pictures to match the layers.
Dec 24, 2008. 2:31 PMLance Mt. says:
I want to make this wireless, any ideas?
Oct 16, 2008. 12:03 PMfreerunnin1 says:
hi, do you think you could send me a picture of where the mic is linked to? cos mine came off and i dont know where to solder them. thanx
Jul 19, 2008. 1:14 AMdulciquilt says:
I just got home from Walmart and could not find these. I checked electronics, toys and the gadget area by the registers, None of the workers in those areas had ever heard of them. They had a more expensive one in the toy area, but I didn't want to pay $10 Where do you find them? I bought one years ago at a truck stop, but can't find it now.,
Oct 8, 2008. 1:59 PMnaw duder says:
I always find them at super sketchy 99 cent stores that sell Chinese bootleg transformers toys
1-40 of 123next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
132
Author:Biotele(Biotele)
Make a better Instructable, and the world will beat a path to your website.
