- Add an Aux-In or music jukebox
- Remap steering wheel buttons
- Remove the Nav warning screen
- Display text like emails and SMS on your Sat Nav, radio, or dashboard
- Access engine and performance data like air/fuel ratio, oil pressure/temp, and VANOS
- Code retrofit parts like rain sensors, run-flat tires, theft alarms, and keys
- Access the proprietary error logs to troubleshoot engine, transmission, or accessory problems.
Continue to the next step and I'll answer a few questions, then I'll show you how to build your own.
Remove these ads by
Signing UpStep 1: What is it?
The Car Kracker is a microcontroller with a bit of hardware to talk to your car. It plugs into a connector in the trunk and has several default modes built-in;
- Audio Jukebox Mode: Play music stored on an SD card
- Advanced Diagnostics Mode: Remove the Nav warning screen, access error logs and read / modify ECU characteristics
- Bus Sniffer: Display data traffic and send test packets
- Audio Aux-In Mode: Enable Aux input to stereo headunits
- Traffic Camera Alerter
- Automatic Audio sync
- Auto Unlock: Unlock the doors when a specific Bluetooth device comes within range
- Data logger + phone home: Automatically send car location and speed via SMS
The Car Kracker works with the following cars;
BMW
- 3-Series, 1998 - 2007 (e46)
- 5-Series, 1995 - 2004 (e39)
- 7-Series, 1994 - 2001 (e38)
- X3, 2004 - 2010 (e83)
- X5, 1999 - 2006 (e53)
- Z4, 2002 - 2008 (e85, e86)
Mini
- One / Cooper / S, 2001 - 2006 (r50, r53)
- Convertible, 2005-2008 (r52)
Land Rover
- Range Rover, 1999 - 2003 (L30)
Unless you want to update the firmware on your Engine / Transmission, It's pretty much impossible - the data bus is designed so that errant / malfunctioning devices don't break anything. Changing preferences (like turning off the door gong) just updates the settings memory, the firmware doesn't change.
Credits
The Car Kracker builds on many people's work - Many thanks to Dr_Acula for respinning RS232, Jochen @ Navcoder, the BMWCoders forums, Rayman for audio playback, e46fanatics, and bimmerforums. Thanks Everybody!
Continue on and I'll show you how to make your own!
Visit Our Store »
Go Pro Today »
You'll just need to connect in Bus Sniffing mode to figure out what commands unlock the doors, turn on the lights, etc. Of course, every car is different.
I found this thread after entering a search for BMW motorcycle ideas. Would this device and software be compatible with BMW Motorrad CANBUS systems at all?
If so, it might well be a better option for most South African bike hobbyists than the GS911 made by Hexcode.
Does it work with a BMW e36 318i?
I'm very excited about this project and I would be very interested about learning this stuff.. I'd like to study sth like this in 2 years so it would give an awesome insight into car electronics and stuff :)
I ask because I don't want to have to get the micro controller board if it isn't required.
Thanks!
btw, very cool project. Good work.
ps. I'm going to try to contact you on a few diff fronts, not sure how often you frequent bfc.
or
lock the doors at a certain speed
Is Car Kracker something like INPA and DIS? Something to communicate with the EDIABAS?
I apologize for all the somewhat unrelated questions. I've done my research for the mechanical aspect of the swap but haven't completed my research for the recoding.
really simple and inexpencive:-)
all you need is BMW 3-Series
