I made a video podcast for the project below.
Please check out my other instructables as well.
Remove these ads by
Signing UpStep 1Materials
All you need for this project is:
LED Flashlight (I got 3 for $9 from Home Depot and made 2 dive lights) The lights should also have a push-button switch with a rubber seal and rubber seals at the threaded joints.
A drill with a small bit (I used a 3/64")
A small tupperware container
A small bottle of mineral oil (its a laxative so get it at a pharmacy for a few $)
In case you couldn't tell I'm being sarcastic. Very sarcastic.
I have a light which caused $50 to build, and is 2200 lumens.
Another light which was about $70 dollars and is roughly 5000 lumens.
The lower lumen one is a sst 90 and throws better
The other one is 5 cree xm l leds and has some throw but mostly flood.
Both are waterproof.
thanks a lot!!
It can be easily melted in a toaster oven, or other heating device. Then, pouring it into a flashlight is easy.
The nice thing about using vaseline instead is that at room temperature it reforms into a solid. Being much more viscous then the mineral oil it will be much less likely to leak out. NO MESSY LEAKS
