loading
Step 5: TRYING TO OUT-CLEVER THE SWISS
I thought, since I was making myself a nice new blade and all, I could add a feature I really like on my CRKT knives - one-handed opening.
Initially I thought that I could do this by enlarging the blade and putting a thumb-hole in it (see Victorinox's own one-hand openers for what I mean) - you can see the intention in the initial blade-making pictures. However, when I actually tried to use it the hole was not really in the right place and it was harder to open than it was before!
My next attempt was to remove the metal bearing the hole and put a small stud in the blade for thumb-opening (like on the CRKT M16 knife) - all went well until I suddenly realised why this won't work on a SAK - the thumb stud obstructs the opening of the adjacent blades!!! DOH.
So I ground it all off and so now my blade is the same basic shape as the original. I left the back of the blade quite rough and with sharp 90 degree un-smoothed edges (where I had ground off the thumb hole and thumb stud experiments) as this will provide a striker surface for firesteels.
Serves me right for trying to out-clever the Swiss.
Why not get a small opinel, open the hole up, and insert it into your SAK?
Opinels have a larger hole, at least for the 91 mm sak
This would be a good hack for a multi-tool as well. Besides the explanations in the instructable (and many comments below), there is another great thing about having at least one carbon steel blade: firestarting with natural flint. Carbon or stainless both work fine for sparking a synthetic flint, but for natural flint, I have never managed to get a spark with stainless. If it is not impossible, I think it must be much more difficult. When using a synthetic flint, it is the ferrocerium material that is scraping away and creating the hot spark. When using natural flint and steel, it is the steel being scraped away (which is why you should use the BACK of your knife if possible). Perhaps stainless does not scrape away and make good sparks as easily. I know you can make stainless sparks with a grinder, but I have not succeeded by hand with a flint.
SAK knives are at 56 on the rockwell scale. as hardness is the primary indicator of edge retention, this would only marginally improve edge retention. the harder steel, and now thinner, is more likely to snap, which springier sak blades are already known for, and rust. also, the sak is likely more accurately built. Wouldnt retempering (or rehardening then retempering) of the factory blade be better at getting to 58rhc?
Do not cut knife blades with a grinder or cutting torch. Especially stainless steel. (which you can not cut with a torch). The blue and black discolouration is a sign that the steel got overheated and thus wil not be as good as it was intended. Always cut a blade with a hacksaw and use a file to file it down to the final shape. Your blade will not have overheated and would be at optimum performance. <br>
After it was 'overheated' by cutting, the steel was heated to about 1300F with a gas torch during the hardening and tempering process. I can't see how a bit of overheating BEFORE hardening makes any difference.<br><br>Sure, excessive heating of a blade AFTER hardening and tempering will ruin it.
Prevention is better than cure. If you burn off some carbon in the overheating process, you detroy the one thing that give the blade its strength. If it is damaged it is damaged. You can minimize the effects by heat treatment but it will never be as good as a blade that was never overheated. <br>
See above. There are 2 things giving carbon steel its strength: Carbon-influenced crystal structure and Work-hardening. You can't &quot;burn off&quot; carbon, but you can remove the carefully planned work-hardening that the original forging created.
aactually....it is possible to loose/gain carbon from steel...you see, carbon has a diffusion rate through very hot steel/iron (can't remember the temperatures and rate right now) <br>this means that if you put iron in a carbon-rich enviroment, with as little oxigen as possible (sealed box full of charcoal), then heat to (very hot-don't know for sure)..the carbon migrate into the iron veery slowly, and after a while, creates &quot;blister steel&quot;, which can then be processed into &quot;shear steel&quot;. the reverse process is also possible (and happens, to a degree, in hardening)
Haha, an *excellent* point (sans the misspelling of lose ;-)<br><br>But considering the relatively low carbon differential, even if done in a vacuum, this effect would be glacially slow, providing a thoroughly insignificant reduction in carbon, especially considering that one is removing significant layers of metal just by sharpening alone, not to mention using a gas torch is actually introducing extra carbon to drive the differential back the other way!
I thought you could NEVER remove carbon from steel ? A cutting torch can NEVER put carbon INTO steel. A torch uses the principle of oxidising the metal where it needs to be cut. In other words you are &quot;rusting&quot; the plate into 2 pieces when you cut it. (By introducing oxygen) Now you know why you can not cut stainless steel with a torch. <br>
if you couldn't remove carbon from steel, you also couldn't put carbon into iron to make steel, could you? Especially not in the way shear steel is made. try googling &quot;traditional steel making&quot;, or something like that. <br /> <br />Also, a heat source can add or remove carbon from steel (in very small amounts), it depends on the amount of oxygen mixed with the fuel before it burns. <br />Lots of oxygen--&gt;carbon is lost and the metal oxidises, forming &quot;forge scale&quot;. <br />&quot;not enough&quot; oxygen--&gt;less carbon is lost/carbon is gained and the metal oxidises far less.. this is why some people place an iron pipe in their forge, then place a bit of fuel(coal/charcoal) in it, before heating the finished blade inside the pipe to heat-treat it. the coal burns and removes the oxygen from the pipe, reducing scale formation
So it is a high-temperature process of rust, and because rust is (as you indicated) oxidized metal and that rust falls off, it also takes whatever impurities such as Carbon that was in the layer with it. If the alloy is consistent throughout, this should not be an issue, but if it is just in the top layer, the proportion of lost metal relative to the diffusion layer of Carbon in the metal could be too great and you'd be exposing lower-Carbon doped Iron beneath.
hmm... I don-t think I explained it very well...if you heat metal in a vacuum, then you would not loose the outer layer(s) to oxidization, because there is no oxygen... but you would loose some carbon (not a lot, but some). If you heated an identical pice of metal in a carbon and oxygen-rich environment (impossible), you would loose iron to oxidization, but not carbon. an environment rich in oxygen, therefore give loss of both carbon and iron, but the carbon loss is far overriden by the iron loss, so its not that important... <br /> <br />clear as mud, aren't, I...
I think the best option is never to overheat steel in the first place. Keep steel as cool as possible while working with it and don't be lazy and cut steel with a torch and you will not have to get too technical into explaining to people why your method of overheating-underheating-impossible-carbon-adding-carbon-removing-oxidizing-back-summersault-heat-treatment is AAAACTUALLY the best way to work with steel and all the other people are so much dumber than you. <br />
overheating isn't really going to do anything though, otherwise forged blades would be cr*p. I was just trying to clear up a couple of points about carbon transfer and scale formation. And how scale formation can be reduced in an carbon rich environment. <br /> <br /> Also, I'm pretty sure you can cut stainless steel with a cutting torch, because it works by melting a hole in the steel, same way as a laser cutter does.
Sorry. I did not mean &quot;you&quot; when I said other people are dumber than &quot;you&quot; I think I am on your side. English is not my first language so I use the wrong word order sometimes. I make knives using the stock removal method. I use various types of steel. Forging steel is different to production steel. One type (Bohler N690) I once overheated. They told me that once the steel changes coulour you can stop right there and throw it in the dustbin and start from scratch. Alternatively you can remove ALL discouloured steel (not just the outside layer because a knife is not an onion) Heat sink and all that. Anyway forging blades is a different beast alltogether. You keep on replacing the lost burnt off carbon everytime you reheat the blade in the coal fire. Coal=carbon. <br />As for cutting stainless steel with a torch I suggest you try it first before you comment on it again. Stainless can not oxidize (rust) therefore it can not be cut by process of oxidation. The oxygen's sole purpose is to oxidize the steel. The process is accelerated immensely by first heating the steel til red hot to excellerate the reaction. If steel could be cut by mere high temperature you would only need one type of gas to do it. Lasercutting can well cut stainless by means of high temparature because it uses temps much higher than that of a torch. I hope I explained OK. (my first reply got lost in cyberspace)
It was never overheated though. Are you implying that a large enough portion of the edge got heated to beyond ~1800F for a long enough time to lose some amount of carbon? Steel doesn't lose carbon that easily.
Thanks thoraxe, I agree - I don't think the 'overheating' at this stage is significant. I think Wulf187 might be forgetting it's a 'hack', not a component for the international space station. There is meant to be an element of homebrew rootsy imperfection..... ;-)
Do not be lazy. If it is worth doing, it is worth dong it the best way you can. You will be more proud of your work if you know that the blade you made is the best it can be. If you like working like a moron and wondering afterwards if the blade could have been better, go agead, as you were... <br>
Is it worth the extra effort, skill, and practice in getting a nice flat edge with a file instead of a grinder?
Yes. <br>
If you over heat, you stress the blade and can cause cracks. It you super heat the blade (about 1700 degrees, farenheit, and up which is glowing yellow-white, your in fear of either melting the blade or burning steel, AKA making it flat iron and burning out all carbon in the blade. Flat iron is almost as maliable as Aluminum. ALmost. It has shit for edge holding abilities.
Not to take anything away from hands-on experience that is typically more respected in these types of discussions, but adding some scientific facts will, I hope, go some ways towards dispelling misconceptions about what actually happens: <br> <br>Steel, in its most basic form, is Iron + Carbon. Melt Carbon into Iron and you get Steel. It's that simple. <br> <br>Now, the graph for carbon steel shows its crystal structure at different steady-state temperatures with increasing percentages of Carbon. It is surprisingly complicated, and this is even before adding such impurities as Chromium, Manganese, Vanadium, etc. <br> <br>In theory, if you melt carbon steel and allow it to cool very slowly, you would indeed get a boring, malleable form of steel. Quenching a specific carbon range of molten steel, however, freezes it into a martensitic structure that otherwise would only exist at a specific, elevated temperature range. Martensite is extremely hard, but also extremely brittle. Tempering then brings portions of the steel out of martensite and into different forms that are less brittle. <br> <br>Thus, for the record, there is no amount of &quot;burning&quot; that would pull Carbon out of the steel. None. (Melting and pulling off slag is another matter, since melting down a blade isn't really within the scope of non-liquid heat-treatment). <br> <br>This brings us to work-hardening, which *is* tremendously affected by excessively high heat at duration. The mechanics at work are very complicated, but consider a single crystal of pure quartz, which is chemically the same as pure sand. Imagine taking a bunch of sand and fusing it into a solid block _without_ melting it into a single crystal of quartz. This is similar to worked steel, where that multi-crystalline setup is the other &quot;half&quot; of what gives Carbon steel its strength. The carbon won't go anywhere during heating, but the crystals will fuse into bigger crystals, which reduces ultimate strength. <br> <br>This is the principle reason why you can't simply cast a steel blade, sharpen it, then expect it to work, and also why you have the classic image of blacksmiths hammering the crap out of blanks or folding hot steel (e.g., in Japanese blades).
I have actually heard of a cast steel blade being produced by a custom maker - if I remember correctly, they were from england....and the name &quot;serrata&quot; pops into my mind...I'm not sure if that is correct, but I do know, for a fact, that there is a knife-maker who casts his blades, but I have no idea how/if he heat-treats them... I will do more research tomorrow, on the place I read about it: britishblades.com (its a knife forum) <br> <br>now, who can tell me how many different types of steel structures there are? As in martinsite, pearlite,... (not as in buildings). <br> <br>oh and, just for the record, you can put a decent edge on pretty much any iron/steel/copper.... youtube &quot;shaving with a spoon&quot; if you don't belive me...
For those wishing to answer his question, start googling &quot;steel phase diagrams&quot; and invest some time in edumication ;-) <br> <br>Bonus points if you can then realize the technical error(s) in my earlier simplification of phase changing steel! <br> <br>
A good trick is to keep a can of water near the grinder and quench the knife often while grinding to avoid overheating.
Though you do qualify the SS comment, it should be noted that the very fact that a steel is &quot;stainless&quot; doesn't make it less able to hold an edge. It's just more difficult to heat-treat properly. More difficult = more expensive to manufacture, therefore your Victorinox (or Wenger) blade isn't likely to be a top-flight production. <br> <br>Joe Talmadge says it better here: <br>&quot;Stainless steels can be forged (guys like Sean McWilliams do forge stainless), but it is very difficult. In addition, carbon steels can be differentially tempered, to give a hard edge-holding edge and a tough springy back. Stainless steels are not differentially tempered. Of course, carbon steels will rust faster than stainless steels, to varying degrees. Carbon steels are also often a little bit less of a crap shoot than stainless steels -- I believe all the steels named below are fine performers when heat treated properly.&quot; <br> <br>See http://www.knifeart.com/steelfaqbyjo.html
just to clear it up a little victorinox and wenger are to different company's wenger being the better of the two but much harder to find but both are Swiss made i do believe. Also im not trying to be rude in anyway just thought this need said
Well said! I do both, but I much prefer the carbon blades. You can produce a better final product for bladework. I've learned how to do the hardening visually using an oxy/propane set up, belt sander and a quenching medium for cutting dies. I applied the same technique for bladework. A very simple, satisfactory product in the end.
I agree about high carbon steel over stainless for knife blades, but wonder about the way you sharpen it. Can't see any advantage of a single angle grind. I used to sharpen knives for restaruants, and always loved the older blades one guy insisted on keeping. Carbon steel, well used, with a lot of great usage left in the blades. <br>Also, you might want to try to find one of the old us military pocket knives made for general use. Stainless steel, US Navy version of a Boy Scout knife. I have one I used from 1972 to about 6 months ago, when a spring broke. Camilus, and a great knife. <br>
Nice instructible marky, I've made a couple of folding knives from scratch and you can get brass pins very reasonably priced from knife makers or use brazing rod from welding suppliers. Get them oversize if you can't get the right ones and then put them in a drill and turn them down to size with some wet and dry measuring often. Also use Araldite or Devcon glue, it's much more permanent than impact adhesive.
The intention behind this 'ible is highly commendable! SAK's are SOOO handy and the blades are SOOOO lousy! Markyb gets to HAVE IT ALL! Nice one!
Just want to add that you can get brass nails. They work great as pins. <br>And one end is already finished nicely, just peen and polish
On thin blades like this one, it will be a good idea, If you only shape the blade before hardening, and wait with the sharpening, that will reduce metaldistortion.
like corey11 said, the process of grinding/forging to shape puts stresses into the steel, so it's best to normalise the blade (get it to non-magnetic, then allow to cool SLOWLY- like, 24 hours is good- dump it in some vermiculite or ash). this alows the steel to relax, and any warpage to be removed without snapping the blade. It also refines the &quot;grain&quot; of the steel (molecular structure) <br>A few normalizations is best, and it doesn't really matter if you have to re-treat the blade.
I like this magnet 'trick'. It's a tip that you don't learn by going hands-on, but not in engineering school. It makes a lot of sense.
very well written ible :) and i like the simplicity of it all, i'v been been making blades for a year or two now and this is one of the better tutorials iv seen. <br>
thanks<br><br>have you seen the video I link to in the 'ible? Green Pete's Knife Making Video - it's just an english dude in the woods making a knife with no workshop, just hand and occasional battery powered tools. Worth a look just for interest!
Im a Blacksmith. For tempering, I set the oven to anywhere from 320 degrees (farenheit) to 345 (again, degrees farenheit). and leav the Blade in there for an hour. Let it cool, put it back in for an hour, let it cool and put it back in for an hour. I get rid of briddleness quite easily, yet maintain a great edge. And the temperature varies for the type of knife you want. Something easily sharpenable will be higher temp, but something you want to remain harder (such as thick-er bowie knives) remain a lower temperature to retain hardness. less collective temperature means harder, more briddle blade. and make sure you anneal your blades or at least normalize them about 3 to 5 times. It removes stress from blades and helps the quench take better, and mainly taking to worry of stress cracks out of the equation
Great job! Very clear and well put. This is a great DIY hack. Like you, I have searched for 'Swiss' knives that offer all the little bits AND have a 'REAL' Blade. Never even though about modding. This would be great for a Multi Tool as well XD
About This Instructable
92,889views
72favorites
License:
Bio: UK freelance General Hacktitioner, health IT specialist and wannabe coder, lifelong hacker of anything and everything including woodcarving, knives, fires, electronics, guitars, furniture, computers, cooking....
More by markyb:Hack a Weber Rapidfire® into an Awesome Woodstove® Simple Self-filter Mash Tun for All-grain Beer Hack a Swiss Army Knife to have a carbon steel blade
Add instructable to:
