Hack a TV Remote
Introduction: Hack a TV Remote
In this instructable i will show you how you can hack your TV remote and to make it work as per your desire!
Hope you like it.
Step 1: Watch the Video!
Step 2: Parts Required
1. Arduino UNO/NANO (or any other commpatible board)
2. IR reciever ( i used SM0038)
3.A TV remote
4. Breadboard
5.Connecting wires
7. LED
Step 3: Download the Library!
Download the IR Remote library for Arduino from here : https://www.mediafire.com/?9qxc9s0c47y94g9
****Steps to install the library*****
1.Extract the ZIP file
2.Copy the folder to the library folder of the arduino directory.
Its Done!
Step 4: Assembling the Circuit!
Make the circuit as shown on the bread board!
Step 5: Testing the Remote!
The next step is to identify the values which is associated with the remote button.
The basic idea is to upload the code and to check which output value from your remote control is given out when a button is pressed.
To check this simply upload the code to the Arduino ,
Open the serial monitor,
and press the button on the remote repeatedly.
NOTE: you will see many values because of the noise(or unwanted signals) from the environment which will interfere in the receptionof the signal.
so just ignore the other garbage values which is coming as result in the serial monitor
and look for that value which is repeated.
Step 6: Configuring the Remote!
Now its time to configure your remote to make it work as per your desire!
Now when you have the values from the remote that you got from the previous step
just take those values and copy it in the code!
Step 7: Its Done!
Yeah its done!
now you can control an LED( as i have done) or control your bot with remote!
The limits are just endless
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    SO I am hoping to do the opposite I have a tv remote and I want to fins out what the signel its sending then recreate that on an ardunio ?
    So, something's missing here. The library <IRremote.h> is found where? A link would be appreciated.
    I have updated the Instructable.
    Also you can find the library here
    I have updated the instructable.
    You can find the library here : https://www.mediafire.com/?9qxc9s0c47y94g9
    There is no library,
    IRtester and Config_remote files are looking "same". (i think)
    You should check this.
    I have updated this instructable, you can find the library here : https://www.mediafire.com/?9qxc9s0c47y94g9
    also the IRtester and Config_remote files aren't the same first upload the IRtester to the arduino to get the hex code of the number you are pressing,when you get the desired values note them down,open the code config_remote and replace the values which you have got with the ones in the code :)
    hope that would work!
