Motivation
Water is a precious resource and our everyday lives are immersed in consuming it. The average toilet uses excessive amounts of water. This hack allows you to minimize some of that water consumption.
I wanted this instructable to be simple enough that anyone could build it with basic tools and materials. I also tried to be material conscious with this project in that: many of the materials are recycled from other things (sheet wood and copper tubing) or second hand (metal bowl), and that it is put together using screws and friction fittings so when the sink has finished serving its purpose it can easily be taken apart and the parts can be recycled.
Remove these ads by
Signing UpStep 1: Materials
9inchx20inch piece of sheet wood
Small plastic funnel
Copper tubing half inch outside diameter
Metal bowl approximately 8 inch diameter
4 feet of Vinyl tubing 1/8 inch inside diameter
4 "L" brackets and small wood screws
Scrap paper
Silicone latex caulking glue
Steel binding wire
Tools
Hand drill
Jig saw
1/2inch spade drill bit
1/8inch drill bit
Center punch
Sharpie
Hole saw 3 inch
Exacto knife
Visit Our Store »
Go Pro Today »
Is this like the japan units?
I think they also set up prisons this way, with enough water power as to not need a tank, so prisoners can't hide things in the tanks.. or maybe make toilet tank wine.. haha!
1) What if you only need to wash your hands, like before eating. Flushing to activate the "sink" would be wasting more water then your saving.
2) We conserve water by following the "if it's yellow let it mellow. If it's brown, flush it down" rule. The toilet is only flushed 2-3 times a day rather then after every use. No it does not stink.
Just some thoughts.
1) Carefully notch the lid and run the faucet hose to a tee attached to the tank inlet hose.
2) Instead of using a simple pipe install one of the levered water dispensers you see on kitchen sinks. The kind that have a definitive on and off not just a momentary press.
Doing these things in addition the to sink install would give you a sink you could use all the time. For extra points notch and carefully drill the original ceramic lid for a true bathroom look. (The basic idea behind drilling ceramics: http://ds5.org/4039 )
Failing that they now sell these: http://sinkpositive.com/web/
But where's the fun in that! ;-)
This is a good way to help save water. Great project.
Toilet water
Toilet water
http://davidmeddingsdesign.co.uk/retro-toilet-cistern-sink-in-copper-and-white-trespa/
95 % reclaimed materials, water saving, hygienic etc
To all the plumbers that found problems with the design... dont attack the poster for the flaws you find post solutions, if your licence is worth the paper it was printed on then you should have the knowledge to help himm fix the problem if not please seek employment at McDonalds.
To the Americans who say "oh well water issues are a third world country problem" take another look at the globe buddy this is the same world the same planet and America is a new country when people have been here as long as they have been in Africa we'll have the same problems
And the scientists the US goverment pay to be smart are too busy determining that santas reindeer were female and creating super computers thats only purpose is to test the theroys of Newton and Einstien.
We need to get together and get it together, adress the problem and and make sure the money goes to the right places
To attack people as you have is of no help at all. Now ,go to your room til you can play well with the other children. ( of course that last part was a little brevity to lighten the mood ) Great ible-- i recently saw a toilet that used the water and the pressure of it comming into the tank to forse the water and waste down the sewer line--ingenious!!
I can't do this to my john now (I rent), but I will do this and some other grey water utilizing hacks as soon as I buy my own place. The main hack I had already planned was to divert waste water from the washing machine to an outdoor cistern for use in the garden. All that will take is to extend and reroute the the drain hose.
http://www.instructables.com/id/Filter-your-Laundry-Graywater-with-Marsh-Plants/
Thank you!
links: http://video.pbs.org/program/old-house/
http://www.tvguide.com/tvshows/ask-this-old-house/episodes/194601
http://www.ovguide.com/tv_episode/ask-this-old-house-season-10-episode-17-reusing-water-from-a-washing-machine-maintaining-small-gasoline-engines-4242493
They also show a manufactured version of the toilet hack so you can wimp out and buy one. I'm sure it works fine, but its not as cool as handmade.
Worthy of mention would be to say that you wouldn't have the problem of standing over the toilet to wash. Also... for a... (shall we say:) "larger" person... having the tank out of the way would allow for more space. Also, you wouldn't have any problems of storing the water. I might suggest, however, that you may want to remove the water flow restrictor from the faucet... so this would allow more water to come forth.
For Ideas:
http://www.nextag.com/under-counter-soap-dispenser/shop-html
When my brother and I build his toilet sink I plan to make an instructable for it, but I think we might be making it directly on the existing tank lid, rather than pouring a concrete one. I may also try making one out of a slab (granite, slate...) and one with mosaic tile. Right now though, I have too many other projects going. One of these days...
If you could 1)find some way to catch the splash from your hands and 2)get past the ignorant people that don't know that the water going into their toilet is the same water going into their kitchen sink, you could market this (with a slightly niced material than particle board).
No adjusting, no "additional" water.
You just flush and wash your hands with the clean water (assuming you're not on a system that flushes using grey water) as it is on its way to the cistern.
The average humanoid needs less than a dime's worth of liquid and even less with bar soap. Water itself has cleansing beneficial bacteria and it's often chlorinated anyway. The uggy parts of your hands are really the nails so if you're thorough with the nails then the bulk of the 'germs' are eradicated during a proper wash.
So, a monthly wipe down of the inside of the tank (when emptied and water is temporarily shut off from it) with bleach or baking soda (or some other green cleaner) should suffice.
Curious tho... what are the effects on keeping a large salt tablet in the tank? That could keep the water highly alkaline so that little mildew build up occurs. But would the salt build up in the water lines?
Also, how to flush the water lines. A nice long soak of bleach or vinegar in the tank before flushing once a month should suffice in de-gunking them, yes?
Again, really ingenius!
-Caleb
I'm picking this up after hacking a completely different system (a modern Geberit in-wall system).
As far as I learned the siphoning dry can occur from a vacuum forming due to a large mass of water passing. This is avoided by having a pipe with a connection to open air in the pipe system behind the toilet, after the siphon.
Is this "air pipe" what you mean with the "supply line"? Is that built in, in American toilets?
Of course the completely separate"air pipe" course this remains untouched in "Geberit in-wall" hack.
The water coming from the valve, normally flowing down free in the reservoir (not in the overflow tube) is lead around into a sink and runs directly back into the reservoir to fulfil it's original function.
Or am I missing something?
Many, many countries don't have a "refill tubes" on the toilet cisterns and they don't have any concerns about it. If it were a real public safety issue they would all have a refill tube fitted.
(Don't worry I'm kidding)
I followed the same idea but tried to make it look a little nicer. Got a serving bowl laying around and drilled a hole in it with a diamond bit. The copper pipe I used has a stainless steel coating and can easily be bought at Home Depot in the toilet piping section (is a water supply line pipe, "flexible copper pipe." I bent the pipe by hand little by little, just don't over bend. Drilled through the toiler lid as well lol.
Note: Bowl need to curve down all the way to the drilled hole to prevent water retention. Get a nice diamond bit ($16-24) so you don't spend more money then you have to. Also, submerge the bit in water when drilling the hole and be patient. Have fun guys :)
im gonna do this... does the water come before or after you flushed?
http://www.toystoreinc.com/servlet/the-3919/Toilet-Lid-Sink-Combo/Detail.
(I'm not endorsing this company/supplier - I know nothing about them.)
I recall seeing toilets topped with sinks used in prison cells on a reality or documentary tv show. I believe that's the same system used here - right? So this isn't an outlandish, crazy, or reckless idea.
The point is, I hope the skeptics will see the benefits. But, with ANY instructable, use your own best judgement and don't install anything you fear may be dangerous OR you don't have the skill to accomplish safely.
Instead of using drinking water to fill the toilet tank and more drinking water to wash your hands. You flush water from washing your hands last time. And fill the toilet tank with the water you wash your hands with this time.
It is a simple but effective idea.
The term free water is referring to using the recycled water. You pay for water once instead of twice.
Thanks for using your grey matter to utilize grey water.
So, after any 'number 1' no need to flush the toilet at all, just wash your hands and that suffices.
Now the best solution of course would be to just pee in your sink ;-). But the wife and any visitors might find that a bit odd, let alone that it might be dificult to even get a wife if one has such behavior ;-)
I knew this thread looked familiar!
To be honest ... what you did is not the prettiest creation (nothing a lick of paint will not cure) but very functional and practical, very well done.
When i tried to convert my UK400 Fluidmaster flush system it did not have an open top nipple vent port (or whatever you call it) , so i had to restrict the bottom half to force the water to the top half vents, drill open the nipple port and restrict some the top vents to increase water flow to the nipple port, but got there in the end and works great.
check it out the vid on:
http://www.youtube.com/watch?v=s-hfNuKrVHc
and watch out for an entry on this site.
A toilet uses about 3 gallons per flush. Washing your hands less than one gallon. City water costs about $1.50 per 1000 gallons; or $0.0015 per gallon. This translates to 0.45 CENTS per flush. NOTE: THIS IS NOT 0.45 DOLLARS but less than HALF A CENT PER FLUSH!
Build one if you must, but this is SO not needed.
(Reference: http://www.irwd.com/WaterEducation/story_of_water/html/costs.htm )
A project like this is flat-out "good" for everyone involved. So what if it only saves you a few pennies? Is it HURTING anyone to do this? No. It is, however, making a fairly significant difference in the long-run. Can you imagine if every single person in a city reduced their water usage per year by 1,825 gallons? How is this not a requirement in cities that often have summer water usage restrictions?
10 x 365 = 3650
3650 x 0.45 = 1642.5 cents
or $16.43 a year.
so, basically you pay for the materials in one year. for an energy saving device that is a great payback time
Places I lived so far charged you per gallons of water used.
Also according to gallons of water used they charged for the sewer use too.
And what ever you save on water consumption and sewer use you will save on sales taxes also.
Indirectly you may save on property taxes by avoiding for the city to have to build new water plants and sewer plants and for conserving energies and water.
So 1 gallon per hand wash saved could lead to more saving than what you directly see.
But saving well over 3,000 gallon of water per household is the biggest savings from them all especially in areas that have drouths.
http://www.acorneng.com/acorn_catalog/PDF/catalogpdf/p/1440.pdf
This project probably cost $50. At Seattle rates, assuming a family of four who each use the toilet 3 times a day (probably a low estimate I'd guess), and assuming 1 gallon of water used per handwashing, you'll pay for such a system in about 10 months.
Regardless, the reason to use a system like this isn't to save money, it's to conserve water. The reason that Wastewater is so expensive in Seattle is that we've outgrown our wastewater treatment capabilities, so we're having to spend millions of dollars on a new wastewater treatment plant. By washing your hands with water that would otherwise be 'wasted' you can help delay such a plant being needed in your area.
(Reference: http://cityofseattle.gov/html/CITIZEN/utility.htm)
A small town has 20,000 citizens. If each citizen did this (and not every citizen has their own bathroom, so the cost would be a fraction of that) and yes, I know I'm dreaming, but let's pretend... If each citizen did this in a small town, and we assume an average of 2,000 gallons saved per year per citizen (I have my own ideas how to stretch this further, but I'll refrain for now) that's a total of 40,000,000 gallons of water that does NOT NEED TO BE CHEMICALLY TREATED for every YEAR this town does this. That's as much water as is in a small lake, or a huge pond. EVERY... YEAR... For one... small... town...
How can anyone possibly argue "oh well, water's cheap." Just how good can it possibly be for the environment to chemically treat a small lake every year? I may even be lazy enough that I won't do this myself, but I absolutely would never try to discourage someone from it. If they made it a legal requirement, then I would happily oblige despite my laziness.
I live in England, and I have a toilet that uses 9 litres of water per flush, and no, I won't be sticking bottles of water in the cistern to prevent water use as the toilet requires that 9 litres to rinse and flush the bowl clean.
So this will be great to reduce the water, plus the room the toilet is in is very small and has a tiny sink on the side wall by the toilet, which gets in the way.
So I plan to make something like this, but instead of a gold bowl and a copper pipe I'm spicing things up a bit. Starting with having a shallow mosaic pool covering the whole cistern (By pool I mean flat surface with raised up edges, it won't be full of water) and mosaicing down the back wall. Then I plan to connect some copper pipes up agaisnt the back mosaics, and have a water fall down the back and another spout to wash hands in and it all flows down into the cistern again to refill it and flush. :)
(I can't refill the bowl with it as the toilet bowls here don't need refilling as they don't suck the water out, so I'm refilling the cistern with it)
Thanks again for this idea. :)
http://www.mayoclinic.com/health/hand-washing/HQ00407
Maybe you write them an e-mail, because they don't have mentioned your name.
this toilet uses hardly any water at all.
andrea
If you do want to mandrel bend, you'll have to find more equipment/machinery than just a tree or propane tank. It may work that way, but it isn't called mandrel bending.
I just spent $25 installing a low flow retrofit kit. 1 gallon to flush + ! gallon to wash = 2 gallons saved.
As an added bonus, because the water level in my basin is lower my butt doesn't get splashed when I experience a violent evacuation. :-)
Cool concept though, I think I'll make a tranquility fountain out of it.
HOWEVER...
both normal ceramics and porcelin are TOUGH as well as brittle.
Usually, drilling results in cracks if too much pressure is applied, or the heat is allowed to build up and cause stress cracking.
IF you break your top, you could always make it into something else useful http://www.instructables.com/id/EG4H19IOUIEP2879MC/?relatedLink
http://www.imagequick.net/PLUMBING/images/2/tina.jpg
Or you could just paint the wood. A coat of sealing primer and a nice gloss finish would keep the whole thing from becoming a petri dish, and make it look snazzy too.
So, since all the water to refill the bowl comes out the spout and through your sink before entering the bowl, I guess this thing runs for a decent amount of time after each flush. That could encourage people to wash their hands more thoroughly, too!
