Motivation
Water is a precious resource and our everyday lives are immersed in consuming it. The average toilet uses excessive amounts of water. This hack allows you to minimize some of that water consumption.
I wanted this instructable to be simple enough that anyone could build it with basic tools and materials. I also tried to be material conscious with this project in that: many of the materials are recycled from other things (sheet wood and copper tubing) or second hand (metal bowl), and that it is put together using screws and friction fittings so when the sink has finished serving its purpose it can easily be taken apart and the parts can be recycled.
Remove these ads by
Signing UpStep 1Materials
9inchx20inch piece of sheet wood
Small plastic funnel
Copper tubing half inch outside diameter
Metal bowl approximately 8 inch diameter
4 feet of Vinyl tubing 1/8 inch inside diameter
4 "L" brackets and small wood screws
Scrap paper
Silicone latex caulking glue
Steel binding wire
Tools
Hand drill
Jig saw
1/2inch spade drill bit
1/8inch drill bit
Center punch
Sharpie
Hole saw 3 inch
Exacto knife
I can't do this to my john now (I rent), but I will do this and some other grey water utilizing hacks as soon as I buy my own place. The main hack I had already planned was to divert waste water from the washing machine to an outdoor cistern for use in the garden. All that will take is to extend and reroute the the drain hose.
http://www.instructables.com/id/Filter-your-Laundry-Graywater-with-Marsh-Plants/
links: http://video.pbs.org/program/old-house/
http://www.tvguide.com/tvshows/ask-this-old-house/episodes/194601
http://www.ovguide.com/tv_episode/ask-this-old-house-season-10-episode-17-reusing-water-from-a-washing-machine-maintaining-small-gasoline-engines-4242493
They also show a manufactured version of the toilet hack so you can wimp out and buy one. I'm sure it works fine, but its not as cool as handmade.
Worthy of mention would be to say that you wouldn't have the problem of standing over the toilet to wash. Also... for a... (shall we say:) "larger" person... having the tank out of the way would allow for more space. Also, you wouldn't have any problems of storing the water. I might suggest, however, that you may want to remove the water flow restrictor from the faucet... so this would allow more water to come forth.
For Ideas:
http://www.nextag.com/under-counter-soap-dispenser/shop-html
When my brother and I build his toilet sink I plan to make an instructable for it, but I think we might be making it directly on the existing tank lid, rather than pouring a concrete one. I may also try making one out of a slab (granite, slate...) and one with mosaic tile. Right now though, I have too many other projects going. One of these days...
If you could 1)find some way to catch the splash from your hands and 2)get past the ignorant people that don't know that the water going into their toilet is the same water going into their kitchen sink, you could market this (with a slightly niced material than particle board).
To all the plumbers that found problems with the design... dont attack the poster for the flaws you find post solutions, if your licence is worth the paper it was printed on then you should have the knowledge to help himm fix the problem if not please seek employment at McDonalds.
To the Americans who say "oh well water issues are a third world country problem" take another look at the globe buddy this is the same world the same planet and America is a new country when people have been here as long as they have been in Africa we'll have the same problems
And the scientists the US goverment pay to be smart are too busy determining that santas reindeer were female and creating super computers thats only purpose is to test the theroys of Newton and Einstien.
We need to get together and get it together, adress the problem and and make sure the money goes to the right places
No adjusting, no "additional" water.
You just flush and wash your hands with the clean water (assuming you're not on a system that flushes using grey water) as it is on its way to the cistern.
The average humanoid needs less than a dime's worth of liquid and even less with bar soap. Water itself has cleansing beneficial bacteria and it's often chlorinated anyway. The uggy parts of your hands are really the nails so if you're thorough with the nails then the bulk of the 'germs' are eradicated during a proper wash.
So, a monthly wipe down of the inside of the tank (when emptied and water is temporarily shut off from it) with bleach or baking soda (or some other green cleaner) should suffice.
Curious tho... what are the effects on keeping a large salt tablet in the tank? That could keep the water highly alkaline so that little mildew build up occurs. But would the salt build up in the water lines?
Also, how to flush the water lines. A nice long soak of bleach or vinegar in the tank before flushing once a month should suffice in de-gunking them, yes?
