3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hack a flash camera into a emergency strobe light
Step 2Hack open the camera!
Start hacking the camera open with a screw driver and be careful not to damage the camera's flash circuit.
Once you got the outer camera's case off, be careful not to touch the circuit board as the capacitor may still be charged, discharge the capacitor by putting a screw driver across the capacitor's terminal and you may get some bright loud sparks.
After you discharge the capacitor, take the flash circuit out of the camera's frame.
4 comments
Jan 12, 2009. 3:27 PMSwishercutter says:
I would discharge the cap with a resistor and some alligator clips to keep it from sparking. I used to use 1 farad caps on my car stereo and this was the best way to discharge/store them. I think it should be noted that after discharging the cap you should short the leads with a bit of wire (or a resistor) to keep the capacitor discharged. Caps will establish a charge from ambient voltages in the air and can charge up to full potential over time. You never know if the circuit that was discharged yesterday is still discharged. I do not remember seeing this in any of the instructables dealing with high voltages so I figured I would point it out.
Aug 1, 2011. 5:07 AMuberdum05 says:
Normally in capacitors that big people connect a high value resistor to the capacitor terminals permanently and then it makes it safe to work around because it is discharged
Apr 21, 2009. 7:05 AMErik J says:
good idea
Aug 11, 2010. 4:29 PMgx27470 says:
ive shocked myself multipple times
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
778
Author:Plasmana
 "Energy cannot be created nor destroyed!"
more »
