Remove these ads by
Signing UpStep 1Required Parts and components
(1) npn 2n2222 transistor (any small signal npn transistor should work)
(1) magnetic NO (normally open) alarm switch
(1) roll of double sided tape.
shrink wrap or electrical tape
3mm drill (bigger is ok, it's just for running wires trough the cases)
24 guage wire ( approximately 2' (60 cm))
soldering iron and solder
![D-Link Wireless Router DIR-628 Setup [Without CD]](http://img.instructables.com/files/deriv/FDQ/ZBHK/GIYWWBMF/FDQZBHKGIYWWBMF.SQUARE.jpg)
I'm really interrested in your work, great job, I own a wireless door bell, but it doesn't produce a simple long sound, but 3 short bip, do you think it could work with your hack? If not do you know a solution to adapt it?
thanks
Just wire this to the relay's input and the high voltage as the output.
What do you think if you integrate IC 555 in the controller to control the frequency of the triggering signal (thus variable with some switches), and integrate IC LM2917 (frequency to voltage converter) to the receiver to turn it into a "several channel remote system"?
can you tell me if this would do the following job please:
I want an alarm to go off at some distance away (wirelessly) when a door opens
not a door bell but an entry alarm
Not sure what you are referring to on the second question. Could you elaborate a little? Turn what on/off?
Wolf, when time permits I will see about editing step 3.
Stephenniall, I hope you will post you work so we can enjoy it. I built my alarm system from this pdf. www.italentshare.com/storage/Alarm/alarm.pdf . It seems to work really good so far. You have to have a basic knowledge of putting a hex file on an IC though and some electronics experience. You can get all of the files for this alarm system here on my little DIY forum. www.italentshare.com/forum/viewtopic.php
You may have to register to view the files. All of the files (including programming) are included in the zip file.
Im currently designing a Cheap multi room alarm Thats cheap (under 10£ about 25$ ) to make
