This Instructable showcases a couple of example projects I made to test out if I could take advantage of this unused "Turbo Mode" and operate a gun turret remotely. I built two vehicles - one using a fully automatic battery powered Nerf gun and another using a battery powered squirt gun with an electric pump.
EDIT: I originally titled this "Hack an RC car's unused 5th channel!" but I've since been informed that it's actually just three channels. The forward/backward and left/right controls are just two channels! If you see me refer to a 5th channel, just imagine I said three, okay?
Helpful Guides:
- I was helped greatly by this Instructable by techbitar: "Use Arduino with TIP120 transistor to control motors and high power devices"
- I also found some great information from this tutorial: "Using a transistor to control high current loads with an Arduino"
Step 1: Supplies List
You will need:
From Target, WalMart, Toys 'R Us, or wherever:
- RC car - try to get one big and powerful enough to carry a couple of extra pounds on its back. I used this H3 Hummer from Target. It was on sale!
- Battery operated Nerf gun, squirt gun, or anything else with a little DC motor in it you want to trigger remotely. I managed to snag this beauty (the Nerf Swarmfire) on sale as well for just $15! I also found this gun (the Super Soaker Thunder Storm) for $15 as well.
- TIP120 transistor Catalog #: 276-2068
- 1N4004 diode Catalog #: 276-1103
- 1kOhm resistor Catalog #: 271-1321
- While you're at it, you might as well get a bigger capacity battery because we KNOW the one that comes with whatever cheap RC car you're using ain't going to last. I used this one - Catalog #: 23-1272
- I found these battery connector clips useful too - Catalog #: 23-444
- Some sort of extra button or switch to put into your remote control
Step 2: About driving DC motors...
Now, we can't just power a DC motor directly from that RX chip. First of all, the voltage probably isn't high enough. Second of all, the amount of current needed to power the motor is absolutely not going to be provided by that little chip (I measured 1 Amp for the Nerf gun!). We need something else to take that 3v signal from the chip and use it to turn the DC motor in whatever toy you're hacking on and off and power it directly from the battery. That something is the TIP120 transistor.
The two tutorials I listed in the introduction of this Instructable pretty much spell it all out. I made up a drawing of the circuit, but basically it is just a circuit that takes the 3v signal from the RX-2 chip and switches the battery power on and off for the motor. The diode, pointing AWAY from ground toward the transistor, is to help prevent back voltage from the motor frying the RX-2 chip.
go-RX-2D.pdf230 KBStep 3: Go crazy with it and make some stuff!
I put in a beefier battery to give myself some more playtime and the car some extra "oomph". Original battery was 6v and lasted a measly 15 minutes. This one is 7.2v NiMH and is 2800mAh. Just solder a connector to the battery terminals of the car, hook in your new battery, and you're good to go! So far as I know the little DC motors in both the car and the toys I used can handle the extra voltage without any issues. If someone out there is more knowledgeable about this topic then I'm all ears!
Visit Our Store »
Go Pro Today »
i am using the same rc hummer but i got it last year. The circuit board is almost idenical to the picture. the problem is the led on the remote just remote just stays on continuously. there are no wrong connections on the remote. i used the 6th pin from the top on the left connected to a switch that is connected to the ground or negative terminal. its the right negative terminal too. when i press right it goes right/back and left = left/back forward rarely works and the gun does not work either. my remote led will act normal but it goes back to troubled after a minute.(it could be because of slight shaking) i am using 6 recharged AA batterys each outputting 1.2 volts adding up to 7.2 volts and the same with the 6 volt rechargeable battery
PLEASE HELP
now i have to use another remote.
i will try using a multimeter.
do you have any tips on soldering the tiny pins?, i have a regular solderer and a pencil tip (?) (thin tip?) solderer.
I'm currently working on a pan tilt assembly controlled by a Wii nunchuk controller and an Arduino. I need to get an XBee radio or something similar to make it all wireless. I might as well turn it into a full blown robot at this point though and let the Arduino drive the car while I'm operating the camera/turret assembly.
http://www.walmart.com/ip/Crosman-AS-Pulse-M74-Dual-Power-Mini/13916909
PLEASE HELP
PLEASE HELP
if stores sold it as a kit they would make alot of money
Thanks a lot, Nic.
im gonna try something...
There are only 2 channels normally used. Backward AND forward is one channel, and left and right is ONE channel. It is just the motor moving the other direction, but on the same channel.
So it has 3 channels, one unused, and not 5.
"The RX2D has five control keys for controlling the motions (i.e.
forward, backward, leftward, rightward and the turbo function) of the
remote controlled car. It can be used together with TX2B."
Note that it says that the chip has "five control keys", NOT five channels. I've seen the TX2/RX2 referenced as a five channel chip set in various places around the web, but perhaps that's a misconception on others' part.
It's a simple circuit - just put a switch or button between pin 6 of the TX-2 chip and ground. If you don't know where to find ground, just use the negative battery terminal of your remote control. Pretty safe bet.
http://dominion-network.co.uk/2012/04/14/when-inspiration-strikes/
but i turn mine into robots with camera,or palm pilot or computer controlled
fairly easy to do
