loading
Step 2: The Voltage Regulator
The simplest way to power the rover and power the PICAXE is to use two different power supplies that share a common ground. To power the PICAXE, you can use the Snap Circuits B5 block (it is also called a 9 volt Holder and Switch). The advantage to using this block is you can connect a standard 9 volt battery to the block and it will deliver a reliable 5 volts to the PICAXE through L7805 voltage regulator circuit (see circuit schematic). The B5 also has two 5 volt outputs--one to power the PICAXE and one that you can use to power another device.
Now you have a convenient way of powering your PICAXE with a reliable 5 volts from the B5 block. As a safety feature for the PICAXE, it would also be a good idea to keep the 9 volts from the rover separate from the PICAXE in case while you are building and testing the circuit something gets connected the wrong way. Thus for this build you will use an H-bridge. It has special circuitry inside it that will prevent the 9 volts from the rover's battery pack from accidentally passing through the PICAXE.
Picture source: www.snapcircuits.net/downloads/ic_info.pdf
<p>Hello,</p><p>We are having trouble getting our rover to upload the completed picaxe program. We have checked the COM number and have tried to upload with the rover both on and off. Are you available to chat this afternoon? It is for a tech fair project. Thank you!</p>
<p>Nice</p>
Cool instructable bro!!!!
nice, have you ever committed any of these snap circuit projects to a pcb?
About This Instructable
14,939views
30favorites
License:
Bio: You can try my projects AT YOUR OWN RISK. There's infinite ways to damage or destroy persons and property. I can't think of ... More »
More by KRA5H:Discover Electronics With Snap Circuits Arcade (A Review) Variable Speed Fan With Snap Circuits, Kano Computer Blink Snap Circuits LED With Kano Computer
Add instructable to:
