Introduction: Hack Your House: Run Both Ethernet and Phone Over Existing Cat-5 Cable
Picture of Hack Your House: Run Both Ethernet and Phone Over Existing Cat-5 Cable
The new fad when building a house is to run Cat-5 cable to every wall jack. These jacks can then be used for either ethernet or phone. When we got our new house built, we chose to get four of these jacks, and we intended to use them for phone service. Unfortunately, the wifi is a bit flaky in places (even with two access points.) This got annoying up until the point where three of the four wall jacks were being used for ethernet, leaving just one for phone. This was a problem.
The solution is to run both ethernet and phone over the same existing cat-5 cable. Every wall jack becomes two jacks, one RJ-11 for phone and one RJ-45 for ethernet. This neat hack could save you a lot of money, as you only have to buy new wall plates and jacks rather than wall plates, jacks, and hundreds of feet of wire.
See how this works in the next step.
Disclaimer: I'm not sure if this is legal. The telephone company won't be pleased if you short your telephone wires together. However, if you do everything right, they won't care. Don't blame me if you shock yourself (unlikely), damage Ethernet devices (also unlikely), damage phones (not as unlikely), damage your house wiring (not too unlikely), or damage your fingers with knives (rather likely).
Step 1: Theory
Picture of Theory
This is made possible because of the wasteful (some may say "spare") wires in cat-5 cable.
Cat 5 cable and RJ-45 jacks have eight wires.
Ethernet uses two pairs (four wires), one for send and one for receive.
Telephones use two wires.
Therefore, you can run both ethernet and telephone over the same wire, and still have two wires left over.
In fact, you could run two Ethernet jacks from a single cat-5 cable, or four telephone lines (though I don't know why you would run multiple phone lines.)
This Instructable will focus on changing wall plates from one RJ-45 (Ethernet) jack into one RJ-45 and one RJ-11 (phone) jack.
Note that I have not done extensive testing with cross-talk between phone and ethernet, though I have seen no degradation in the quality of either when both are in use.
Also note that this procedure will not work with PoE (Power over Ethernet) devices. Nothing bad will happen, it just won't transmit power. See step 13 for a possibly unsafe way to keep your PoE and add phone service. Also, it will not work with gigabit ethernet-- gigabit ethernet uses all four pairs. It will work fine at 10/100 Mbps which is sufficient for most people.
Step 2: Parts
Picture of Parts
1. A house wired with Cat 5 cable and RJ-45 jacks
  • To see if you are eligible, see check the three things shown in the picture. Your system also needs to converge at a central box where you can place an Ethernet switch or router.
2. An existing modular jack system.
  • Our house used Leviton QuickPort plates and jacks from Home Depot. This is not strictly necessary, but if you don't you will have to spend extra money on more jacks. This Instructable will assume you are augmenting your existing modular jack system.
3. Wall plates with an additional hole, one for each plate to be replaced
  • In my house, one two-port plate could be reused, but a three-port plate and many more two-port plates had to be purchased.
4. RJ-11 jacks, one for each plate to be replaced
  • If your house did not have modular RJ-45 jacks you will need to purchase those too.
5. Half of a 6-ft or longer phone cord, one cord per two jacks.
5. Either a multitool, or a screwdriver, pliers, wire cutters, wire strippers, and knife (razor helps.)
6. Soldering iron and decent soldering skills. "Helping hands" suggested.
In total, to rewire five jacks, I spent about $28. This cost does not go up linearly, as you can purchase items in bulk.
Step 3: Disassemble Existing Plate
Picture of Disassemble Existing Plate
Unscrew your plate from the wall. Pop out the RJ-45 port, and pull the wire out from the wall as far as you can.
Step 4: Remove a Pair
Picture of Remove a Pair
Ethernet does not use the brown or blue pair in Cat-5. I chose to use the brown pair. You may use either.
  • Be warned that if you use the blue pair, your RJ-45 jack will no longer be able to carry phone service. However, you will hopefully have a separate phone jack soon, so this will not be a problem in the long run.
Using a knife or small screwdriver, break both of the brown wires as close to the jack as possible. Avoid all the other wires. If you break any of the other wires, you may have to redo the entire jack.
Using a knife, cut out a small section of the cable jacket about three inches from the jack.
Using a knife, screwdriver, or pliers, lift up the brown twisted pair and remove them so they stick out this hole.
  • I do not recommend using a knife to do this, as you may damage other wires.
Step 5: Crimp Phone Jack and Reassemble
Picture of Crimp Phone Jack and Reassemble
At this point, you need to establish a standard way of wiring the phone jack. It is a completely arbitrary choice.
Here is how I did it:
Brown Striped Cat 5 -> Red Telephone
Brown Solid Cat 5 -> Green Telephone
Follow the instructions on your phone jack to crimp the brown pair into the red and green wire slots on the jack. This must be done in the same order on every connection (see above.) Use a knife to trim the extra.
Once this is done, reassemble the jacks using a faceplate with one additional hole.
This end of the connection is now done.
Step 6: Locate Head-end of Cable
Picture of Locate Head-end of Cable
You will need to find the origin of the chosen cable. Mine were conveniently labeled and came with a paper showing where each one goes. If this is not the case for you, you may have to trace them using a cable tracer. You can borrow this from your local networking guru.
My cables were terminated with RJ-45 plugs. If you have jacks or loose wires, your job is easier.
Once you have located the other end of your cable, remove it from the panel. If possible, bring it to a flat surface you can work on.
Step 7: Remove a Pair Again
Picture of Remove a Pair Again
Using a knife, remove a small section of cable jacket as close to the RJ-45 plug as possible.
  • Now is not the time to damage wires-- if you do, you will have to crimp on a new RJ-45 plug, which means more money for parts and a second trip to your local networking guru for a crimper. However, if this happens, you can simply not crimp in the brown pair and not have to remove it afterwards. It's still not worth it to re-crimp the ends.
Using side cutters, clip the brown pair close to the plug.
Remove a small section of cable jacket a few inches from the RJ-45 plug, as you did in step 4.
Again, using a small screwdriver, pliers, or a knife if necessary, extract the brown pair so it sticks out from the cable two or three inches from the plug.
Step 8: Mutilate Phone Cable
Picture of Mutilate Phone Cable
Take a phone cable and cut it in half. You only need half of a cable per jack.
Inside you should find two wires surrounded by a jacket, similar to Cat 5 cable. Carefully cut and peel back the jacket, leaving an inch or two of wire sticking out. Trim the excess jacket.
Step 9: Select Proper Wires
Picture of Select Proper Wires
You need to figure out which wire in the phone cable is red and which is green. Mine were both physically colored black. To figure this out, you can find a phone cable that does have colored wires and use it for reference (you can see the colors sticking into the clear jacks.) You can also search online or use the picture provided here.
Step 10: Solder Phone and Cat 5 Together
Picture of Solder Phone and Cat 5 Together
Strip and solder the red phone wire to the striped brown Cat 5 wire, and the green phone wire to the sold brown Cat 5 wire.
  • I found it helpful to only strip the two wires I was going to solder together, to avoid mix-ups.
Tape the two wires separately to avoid shorting them together. Neither you nor the phone company would appreciate this. Tape the entire custom connection to the Cat 5 cable so that it appears nice and neat.
Step 11: Test
Picture of Test
Plug the RJ-45 plug into a router or switch, and your computer into the RJ-45 jack. Test this connection.
Plug the RJ-11 plug (the one on ex-telephone cord) into the phone junction panel.
Plug a phone into the RJ-11 jack. Listen for a dial tone.
Step 12: Troubleshooting
If both connections work, congratulations! You can get pretty fast at the process and do each jack in half an hour or less.
If the ethernet connection does not work, you need to find the problem in the wires. You may have accidentally cut an important wire trying to remove the brown pair from the jack. You may have also done this where you tried to remove the cable jacket.
In most cases, the only good way to fix this is to re-crimp the terminator onto the cable. Other fixes such as soldering will greatly degrade the quality of your connection. Remember that twisted-pairs in an ethernet cable can only be untwisted for half an inch on each end of the cable, or else crosstalk will occur.
If the phone connection has problems, first examine the physical wires. Most likely the bending or cutting of these wires has caused a break in them. If you find a break, it is acceptable to solder it to fix it-- phone is not as high-quality as ethernet. A multimeter may be helpful here.
Afterwards, check that your wires are attached to the proper place on the jack. One wire should go to the red terminal, and one to the green terminal. Do not confuse the green terminal with the solid green Cat 5 wire.
Finally, check that your wires are the same on both ends-- that is, brown striped to red, solid to green. Most likely it is a different problem, as long as you were diligent enough to double-check all the orientations.
Step 13: A Few Words on PoE
Picture of A Few Words on PoE
Power over Ethernet is a technology that allows ethernet devices such as access points to operate without the need for wall power. It is not used widely except in businesses.
It sends power by placing a potential between both brown wires (-) and both blue wires (+). Since you disconnect one of these pairs using this method, PoE will simply stop working (it is not dangerous to use PoE devices, the wires are simply disconnected.)
If you desperately need to use a low-power PoE device, you may get around this by only using one wire from each pair for phone. One example of this would be the striped brown wire and the striped blue wire. Then, the solid brown wire and solid blue wire would continue to work for PoE. However, this halves the maximum current that the cable can handle and may present a fire hazard when using large power-hungry devices. I do not recommend this, but it is a possibility.
RobertB737 (author)2017-11-29
This works for 100Mb network but if you ever plan to or are running a Gigabit 1000Mb network don't do this as Gigabit will use all 8 wires.
lperkins (author)2011-12-04
Rather than hack apart your wires in the wall, you can buy or build what's known as a "splitter." You put one on each end of the wire. They're easily available to split the cable into two ethernet channels, or four phone channels. Making a custom one is as easy as doing what you did here with a short piece of cable and putting a plug on the end of it. Keep the wires as close to their original configuration as possible to minimise the amount of interference you pick up. (Read don't untwist the wires any more than absolutely necessary, and have them fork off from each other at the last possible moment.)
The advantage to doing it this way is that it's not permanent so you can reconfigure your panel any which way you want in the future.
I can probably be convinced to post an instructable about making splitters if anybody's interested.
Ashokalgude (author)lperkins2016-01-18
is it possible with Gigabit cabling? there are RJ45+RJ45 and RJ45+RJ11 splitters available in market so suitable cable RJ45 to RJ11 also.
RobertB737 (author)Ashokalgude2017-11-29
No Gigabit 1000MB uses all 8 wires
DavidO256 (author)2017-04-21
It's called 10Base-T wiring (Jacks) when you wire the jacks that way it's been around the Universities in Canada since the 1990's
xvzxvczxcvz (author)2017-04-09
nice post
ŽAkařaíß made it! (author)2016-10-12
RJ45 RJ11
OfeliaM5 (author)2016-09-25
Hi. This is the first time i try anything like this so i am to say the least stupid when it comes to this. So we live in an old house and out on the country. We already have a century link connecrion but wanted to add a second one. I ran a cat 6 from the phone line only connecting the blue and white and blue wire. I then connected it to a cat 6 jack. I proceeded to conect my new century link router to it and got nothing. I dont understand what im doing wrong?
Ashokalgude (author)2016-01-18
How to Know whether it is Gigabit or ordinary cabling? cannot we use RJ45 +RJ11 female adopters at both wall points to run phone off course with filter.
gigabit connection repaired 4pairs... 100mb connection required 2 pairs
prototype_mechanic (author)2016-04-02
what else you can do with cat5 free wires
1. phone+ethernet(100MB)
2.ethernet 1G
3. poe(power over ethernet) active/passive
4. AC(for advanced users)
5. dorbell
6. etc
on first photo phone and ethernet via cat5
on second photo 10 ethernet,2phone lines,1 1gb, and 220vAC (for power routers, switch,2home server)
Stonie (author)2012-07-21
Hey nice post!
Lots of good information in the comments too ;)
One question: Given that the phone line is 'live' is there any problem soldering it? with an iron that is earthed?
I have 3 Irons, one is an ESD safe station, second a Goot 12watt and a el cheapo 25watt, all three have an earth pin on their wall plugs?
I guess earthing the live wire is not ideal?
Cheers,
Stonie.
Stonie (author)Stonie2012-08-05
To answer my own question… I checked with some line techs and apparently MDFs are soldiered live. So earthing via your iron is ok… Also shorting the line (closing the circuit) probably is not a big deal either… at least not in Australia.
Brett19 (author)Stonie2015-11-30
Great question, I had to read it a few times to get it. Thanks for answering your own post. It's funny how just typing it out helps us to think it through. What's could be wrong with earthing a live wire? The function of an earth ground is to ground any stray voltages. Just don't get between your voltage/amp source and the ground. or it'll will pass through you. And here is a life saving tip for everybody....whenever you must work in a live voltage situation, always keep one hand in your pocket, so the voltage won't pass from one hand to the other via your heart! Of course you should always avoid working with live voltage.
mickeyaaaa (author)2015-06-30
thanks, quick search and your article means we can still use the fax machine in wifes office....for the 1 fax we might send every year or so....
KenM4 (author)2015-01-05
Thank you for the post, this is great. I have just one question to fully understand this. My home is wired similar to yours but it's only using the two phone wires now, the other 6 are unused. I understand how to hook up the output jacks.
My question is how to wire back to the router. Can the wires be merged together and connected to one RJ-45 and plugged into the router or does every wire have to have it's own RJ-45 jack and port space in the router router? I'm just trying to go one-way out from the router. The attached picture shows how my electricians initially used one source cable and split it into 5 or 6 cables that run throughout the house. Do I need to pull those connections apart or just put an RJ-45 on the unused wires in the source cable? Thank you!!
Octataral (author)2014-11-12
Actually as long as you are only wanting phone service, it doesn't matter if you get the red and the green (tip and the ring) mixed up. It's just a circuit. But if you're running ADSL or some other device, like those systems that help people dial an emergency number from a bracelet or necklace, then it does matter. :)
BaileyW1 (author)Octataral2014-12-06
Its not a matter of life or death, but matching green/red with white/blue, etc does matter. One is tip and one is ring and if it is wrong you will have incorrect polarity which can affect some phone devices. I only know this because Im a phone technician ;)
MarcoManG6 (author)2014-08-17
Good info, right now I am also sharing my Cat5e for both phone and internet. I understand I cannot run Gigabit Ethernet because of of this. I just upgraded to 500mb service and the question I have is will this affect the speed. I am currently using only one twisted pair for the phone line? Thanks
leonthedruid (author)2013-03-04
Keep in mind this will work for 10baseT and 100baseT but in no way compatible with Gigabit Ethernet.
simdude2u (author)2012-10-19
But you can't run gigabit ethernet!! because gigabit ethernet uses all 4 pairs of wires.
mednasrallah (author)2012-01-18
You might not know that you can plug RJ11 plugs into RJ45 sockets, it's specifically designed like this. So your 2nd socket could be an RJ45, this could be a bonus depending on how easy it is for you to find RJ11 sockets.
Only downside to this is someone trying to plug a computer etc into it.
Ideally should have double cable runs to every panel in a house anyway, and then patch as you need. It's nice to see some places are being cabled like this now - but then seeing single runs makes me die inside ;)
bshad74 (author)2011-12-27
This is very good article. Thanks. My question is that;
I have no phone at home but have DSL throgh ATT (they call it Dry Loop).
I have my Wireless modem in the home office and connected to phone jack (which is Cat5) in that room and wireless is use around the house (which is wired with cat5 all across).
I would like to use the other jacks in the house as Ethernet outlet to connect my TV media drive to avoid WiFi slowness. they are connected through wifi. How do I connect my cat5 phone jacks to my modem while continue to receive dsl connection?
How do I do that?
T3Hprogrammer (author)bshad742011-12-28
First, you should move your DSL modem into the Cat-5 junction box, which is hopefully the same place that your DSL comes in. Then, you can rearrange the cables so that the DSL goes straight into the modem, and the modem's ethernet goes into the wires that lead to the rest of your house.
If your DSL comes in nowhere near your junction box, and is for some reason wired up to one specific jack, then you will need to somehow get an ethernet line between the DSL modem and the junction box. There, you can place an ethernet switch and plug all of the pre-existing wires into it.
festec (author)2011-12-26
Lots of all new million $ homes in Calgary only have one cat5e installed for telephone and no data jack? That's not a problem for Contact Direct Connect but apparently it is a problem for the other Contractors they need two cat5 cables for the same level of function at twice the cost..
http://www.contact-directconnect.com/images/Smart-Jack.jpg
Data networking, which should be an inherent capability of a well-designed phone cabling system, its completely unsupported by the common "hard-wired" design. If data networking is done, separate 4-pair cables are run to a modular patch panel. The problem with this is that now some wall jacks are just for voice and others are just for data. Each jack is less powerful because of its specialized use. Total system cost must be much higher for a given level of functionality. The system will work, but is neither structured, nor optimal.
goodmike (author)2010-06-07
There seems to be some basic misunderstanding about how the telephone company gets from its central switching office to your house. First of all, almost all single line, residence phone lines come into your house on one pair of wires. If you have DSL in addition to local phone service, you still only have one pair of wires (identified as "tip" and "ring"). Both voice and data have distance limitations when transmitted over wire...enter fibre optics. The phone companies use fibre optics to overcome the distance and bandwidth limitations of metallic conductors. In my area, something called a DSLM (commonly referred to as a D-Slam) is used to carry voice and data signals great distances from the central office to your neighborhood. You have probably seen repairmen working at a green metal box about 5 feet high, 3 feet deep and up to 15 feet long. That is the DSLM terminal that server the neighborhood. It is fibre optic from the central office to the DSLM, then one metallic pair to the individual house. One DSLM can serve 24 or 48 or 72 or more individual homes. However, at the beginning (the central office) and at the end (your house) you still have one pair of wires.
By the way.  My knowledge comes from a 40 year career with BELLSouth in Florida and North Carolina.
pcooper2 (author)goodmike2011-08-24
A DSLM or a Remote Concentrator Unit (RCU) make it possible to provide ADSL service to customers who are tens of miles from the central office, where ADSL is usually limited to 18,000 feet.
Groxx (author)2009-09-23
I quite like this setup, though I would miss my gigabit connections for remote backups. And I feel compelled to say that while I like the red/green labeling "for the benefit of the color blind", I must ask... If they're color-blind, how will they tell red/green when actually doing this? (..though while typing that I realized that, if they kept a red light handy, they could tell the red one by the one that gets lighter when lit by red.)
blackjack929 (author)Groxx2009-11-19
 Groxx - you should be ashamed! Treating the disadvantaged as though ONLY the people who see color and color code items!
We actually can compare shades - and if you put green and red side by side you see a difference in shading. But there is no red or green. And we learn tricks too about using striped wires as guides and just generally in worst case scenarios just make sure the "shades" all line up. Just an FYI from a 20 year vet of the tech-age. You should see me with resistors!
cowen (author)blackjack9292010-04-04
I had a cable tech that was color blind.
He ran circles around the guys that could see colors.
His terminations were better then the non disadvantaged guys.
Now I did not know that he was color blind and once I found out I was truly amazed.
There are a lot of people out there that are handicapped and can overcome the disability and you would never know it.
Personally I try to contract persons with disabilities most of them work better then someone with out a disability.
pcooper2 (author)cowen2011-08-24
Most men with color blindness are red/green color blind, meaning that they can't distinguish red from green. They can see other colors, though.
hintss (author)blackjack9292010-07-20
SMD ones have the value printed on. just sayin'
tristantech (author)blackjack9292010-02-27
It doesn't matter if your color blind and mix up red and green because they aren't polarity sensitive.
cowen (author)tristantech2010-04-04
Until you update to digital which is polarity sensitive in most cases.
Manufactures are making Data equipment IDIOT proof so that all that is needed is to run a cable and punch the "wires" down in the slots at both ends with out making sure it is right.
The ports will align themselves to the right pin outs regardless of the (fancy term) Wiremap.
Wiremap is a method to see what wire is to what pin.
Orange pair
Green pair
Data pins
Blue pair
Brown pair
Future use and or grounding for EMI interference.
Structured Cable comes to mind.  The cable in a whole provides the stability and the green and orange are twisted more then the blue and brown pairs are.  Cat6 has even more done with it.  I will not go into a whole explanation of what mathematical science is used to create the cables twisting just know there is.
This basically has to do with magnetism.  These pairs are twisted together in counter twisting rotations. If you have two magnets a North magnet and South magnet they repel each others force.  That is what is going on inside the cable.  That is why the cable has 4 pairs that are lined up the way they are and why each pair is twisted together in better grade cable there is a plastic separator between the pairs(cat6 typically).  Splitting out pairs destroys this entire design.
Running  cables close to EMI (transformers and such is bad too) is reduced by this design but deliberate placement should be used.
The center pins are reserved for line one teleco but it depends on what you are plugging in.  That is where the codes/standards/practices come into place.
EIA/TIA established this years ago (1980s) and we technicians follow these today (2010- and forward) so that one cable can be used with any configuration with out having to tear it up and figure out what the person was thinking that connected the jacks and plugs in the first place.
We follow a strict 568B straight through pattern for a reason.  Specialty cables are heavily marked as such.  The inexperienced just slap it together and hope it works and disclaimer that it if does not they are not responsible for damages.
shtihl (author)2010-04-04
if you wanted to avoid soldering, you could pick up a set of Telephone Wire Splice Connectors which are located in the same section of the big box hardware store (starts with HD) as the other parts you will buy for this DIY. they are red and allow you to crimp two wires into one by simply squeezing the splicer with a pair of pliers or the needlenose on your multi-tool
cowen (author)shtihl2010-07-23
You CAN NOT use this on DATA. To use this on a data cable these untwist the cable. From the above discussion about the need for twisting of the pairs these splices are designed not to work. It is not IF you will have a failure it is when.
You CAN use these crimp splices on DATA. Make sure the pigtails are kept as short as practical. The pigtails are an impedance discontinuity in the cable, but as long as one has very few of them and the size of the discontinuity is kept small, most systems have enough tolerance in them to still be able to work reliably.
T3Hprogrammer (author)cowen2010-07-25
The method described in the instructable does not modify the twisted nature of the ethernet wires (I was very careful about that.) Be sure that if you use another method (such as these splices) that you leave the data wires twisted up until 1/2" from each termination.
elias.alberto (author)2010-09-20
I don't know how different are your phone landlines from the ones in Brasil, but what I've noticed is my phone will work regardless of the polarity of the wires. As long as I connect both, the phone works.
Dranoweb (author)elias.alberto2011-02-26
Polarity does matter.
Most phone have polarity correction built in and hence you won't notice any difference on your phone, but your modem and adsl signals will suffer with reverse polarity.
Phone lines are 48VDC on idle, 90VAC on ring and around 30VAC when in use.
you can check with a multimeter but red should be negative (odd but true) and green should be positive.
If you have a second phone line, black is positive and yellow is negative.
pcooper2 (author)Dranoweb2011-08-24
Phone lines are -48 VDC open circuit. The ring signal is 30-34 VRMS superimposed on the DC, so the swing is roughly between ground and -96 volts.
The old 4-conductor, beige jacketed household telephone cables typically used red and green conductors for the first pair, although this is not true of CAT-5A cable which uses eight white wires with various color stripes. Wire pairs are twisted together in CAT-5A cables.
If you don't know what VRMS means, you have no business fooling with this stuff.
zydicious (author)2011-07-03
Wonderful instructable to inform the masses of this. First, this is indeed perfectly legal. When my ex-wife's business moved to newly built premises the jacks were actually set-up for this with only the actual wiring left to do when I set up all of their office equipment.
roadie.web (author)2011-04-14
Is there a length limit to this setup? I wanted to hook up my PS3 in my basement to a switch in the upper floor. This means it passes thru 2 floors (Basement - Main floor -Upper floor).
The Cat5 cable I'm planning on using is also carrying DSL signal. However, I'm just going to stream movies to the PS3, that means, when I'm downstairs watching movies, I won't be surfing the net.
I'm not looking for gigabit speed, maybe just 50Mbps for the HD movies that I stream; does it look like it's going to work for me? Thanks.
T3Hprogrammer (author)roadie.web2011-04-15
The length limit for cat5e cable is 100 meters, assuming you preserve all twisting at the terminators (max. of 1/2" untwisted). I would guess that a noisy DSL signal running right next to it would do no worse than halve that figure, so you should be good.
msalinas-1 (author)2011-03-14
What kind of jack is on the Bottom? That looks like one of those Kwik Jacks. Is that right?
http://www.discount-low-voltage.com/kwikjacksystem.html
JettaKnight (author)2009-07-23
This will work in a pinch. However, the noise coupled from the POTS, will induce errors (i.e. slower bit rate) onto the ethernet. It's certainly a good instructable since it's valuable information as long as you mind the caveats. One thing that hasn't been mentioned - lightening. If lightening strikes the phone line or near the line coming into your house it will be coupled on the ethernet; possibly destroying your switches and computers. For my house, I ran separate lines for phone and data. Several locations use the same data cable for two ethernet connections. And the line coming into my house is fiber so I don't worry about lightening, unless it's really, really bright.
This is a very good point-- at our old house, lightning struck our cable line as it entered the house. We have Fios now, but there is still some copper near the house.
cowen (author)T3Hprogrammer2010-07-27
GLASS can conduct a lightning strike too. I just finished a project replacing a fiber that was melted by near lightning strike. Not properly grounded it took out the entire run including both closets and all the gear in them. The GLASS acted as a conduit for the strike to follow. Also learned this in a Fiber termination class for FIOS.
rondos (author)2009-07-17
there's nothing illegal or dangerous here, in fact the phone company sends both your internet signal and the phone line over the same pair of wire. It's called multiplexing.
cowen (author)rondos2010-04-04
No one saying its illegal or dangerous.
What s said is that the concept is faulty for today's standards.
Yes it may work but not to the fullest extent of the specifications design capability.
About This Instructable
819,736views
325favorites
License:
Bio: http://www.awesomelicious.com/about/me.htm
More by T3Hprogrammer:Hack your House: Run both ethernet and phone over existing Cat-5 cableMake a Fog Chiller for $10Shock your Trick-or-Treaters
Add instructable to:
