Hack Your Battery Dremel to a Wired One
Published
Introduction: Hack Your Battery Dremel to a Wired One
About: I'm Joshua I'm a simple guy who's a gamer I'm 23 (super old) I love to hangout with friends Play la PS4 and PC I love build and modify. Like to learn new things.
Hello every I’m ALazyAzzPanda here, to so post my first instructable EVER WOOT WOOT!!!
This instructble will show you how to turn a cordless (battery powered) Dremel to have an always ready energy source to it. You may be wondering “Why would you do that?”. Well at the time I started using it I only had one battery pack and it tend to drain rather quickly. Since I normally use the dremel a lot on gunsmithing and case modding, it peeved me that I had to wait 4 hours for it to charge, then only lasted 15-20 mins TOPS! Then I went look for two power packs, I found nothing. So it was back to using what I had readily available. Moving on to the steps to make one yourself.
I apologize for blurry picture I only had my camera phone
Materials Needed
1x Cordless Dremel
1x Adjustable Power Supply (or tattoo machine PSU)
1x t-6 bit Screwdriver
1x Tattoo cord (Dual uses) [AUX or 2 banana pin]
Optional [Both will be covered in this]
A) Tattoo foot pedal (To turn it off or on without turning off the power supply)
B) If you don't have tattoo cord you can use 2 Power Alligator clips and 2 1/8 ga wire any desirable length 5ft(1.524m)
Step 1: The Calm Before the Storm
Well before we got started taking the dremel apart, first get the power supply/connectors set up and ready to use.
1) Have connector secured to wire
2) Make sure your PSU is off  before plugging/wrapping wire end in
3) After all is connected TEST IT. For this a used a 20mm pc fan
(I'd rather lose a cheap fan if something went wrong)
Step 2:
Taking the dremel apart
This is pretty easy to do, just make sure you pull off the power pack and attachments are off it. Once done with those two things you’ll now twist the top off. After that you'll have two T6 screws. TO THE NEXT STEP!!!
Step 3:
Now that you have the cover off the rest will be just as easy. Pull the whole motor out
(WARNING: Be CAREFUL not to lose the bit locking spring on the housing.)
Then pull off the blue bottom part (should slide off), you should see two pongs one positive and will have red dot next to it. Thus meaning the other one is negative.
Step 4: Testing the Motor
Test the motor with the power supply  at 3 to 4 volts being speed 1 and then speed 2 at 6 to 7 volts[7.2 MAX for the dremel I'm using]
If all is well your ALMOST DONE!!!
The AUX info
http://www.youtube.com/watch?v=OgSIGViP8pU
Step 5: Putting It Back Togather
Now the last part putting it back together which is easy but I didn't just leave the wires hanging.
What I did here was simply took apart the battery pack which consisted of 6 AA rechargeable batteries.
I drill a small for the cord to come out I also had to cut part of the top for the clips to fit right .
All and all went pretty well. And I want to thank those ahead of time for reading this.
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    can you use an old wire..like a old lamp wire... ?
    thanks
    3 Comments
    How would i go doing this mod to a dremel 7300? I suppose i would have to make psu out of an old pc psu...?
    Yes, but you have to put the blue selector switch on (Which I lost). Under 5 minutes to put it back on which is pretty cool
