Hack Your Car Badges!
74,503
133
10
Posted
Introduction: Hack Your Car Badges!
This is an oldie, but goodie, taught to me when I was just a wee child by my dad. You can remove most of your vehicle's trim with your dentist's best friend...dental floss!
Badges, generally, are stuck to the car using two methods, posts or adhesive tape. Post-mounted badges are easy to remove since they only require a nut driver or the right sized socket, but I've seen tons of paintwork damage done by well meaning folks using metal paint scrapers to get their adhesive badges off. If it's good enough for 'your' enamel, then floss is definitely good enough for your car's as well.
This takes only seconds and makes you wonder why you never thought of it before :)
Step 1: Visit Dentist...clean Teeth, Score Free Floss!
First, go ahead and take this opportunity to go visit your favorite dentist and get those chompers checked up...they'll love you for it. Your dentist will reward your diligence by giving you a shiny new toothbrush and some free floss. I'm sure they won't mind if you re-purpose a little for this job! Any kind will do just fine.
Step 2: Now the Hard Part...
Wrap the floss around your fingers (like your dentist taught you) and gently saw the floss between the badge and your car's paint. The sawing action cuts the foam core of the adhesive tape and allows the badge to fall right off.
Don't try pulling the floss through, it'll just snap. Saw back and forth to get a good cut. If it does snap, don't worry, you've got plenty more in that little box plus you know where to get more if you run out!
Step 3: Clean Up the Mess...
This doesn't require a college degree, but you should use your wits for this step. An adhesive remover will take the remaining glue off without any problems. Acetone and paint stripper are just plain stupid! Yes, believe it or not, this actually has happened to really, really - seriously - dumb people. Don't be one of those people, just go out and buy some. You can get it from your local hardware store, auto parts store and, of all places, Walgreens! They also use the stuff for removing the glue left over when you take bandages off, so look in the medical section.
I only put the remover on a rag, not on the paint. I do a quick wipe of the foam to soak it with the remover, then, using my finger inside the rag, roll the remaining tape away from an edge. The tape will start to come off in a nice strip if you're slow and careful. Again, take your time and be gentle. Sometimes there will be dirt stuck in the crevasses that will scratch your paint if you scrub too hard.
One last note - depending on how long the badge was there and the color of your car (red is always a problem), the color under the badge might be different than the rest of the car. Now would be a good time to get out the can of compound and give your baby a good polish and wax. It'll even out any color differences and make your car shine!
Hope you enjoyed this one!!!! Till next time...
James Irmiger
Lead DC - Facilities Manager
TechShop SOMA
San Francisco, CA
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
10 Comments
Love it. I'm gonna remove the Hybrid badge from my Prius and replace it with this. Fans of The Hitchhiker's Guide to the Galaxy will understand.
You could've keep the double Os + S and spelled is as OOPS. :)
b careful, some badges have line up pins and the metal has holes, so after you remove the badges there will be holes, that is what happened to me with mi lexus, i had to fill in the holes.
Pre- heating with a hair dryer softens the hold of the glue and makes it easier to remove stickers as well as badges.
To remove the residual glue I rub with a pencil eraser and/or use a water dispersant spray like WD40. It works as well if not better than the goo removers and is usually cheaper.
the hair dryer is the method that I am familiar with, but the combination of these two methods is an even better approach.
...one of the best drivers ever....Mcrae. RIP.
Nice "ible" too. Thumbs up!!
Floss to remove badges - BRILLIANT! I remember we used to lay down waxed cotton thread in gaps before applying sealant in aircraft cabin floor panels: the little "tail" of thread left protruding was simply pulled up and out to break the seal at a later date. Got me thinking... mmmmmm.
THANK YOU FOR THIS.  I've always wondered how to get those things off.  Mostly I want to take the dealer's stick-on logo off the car.
It's okay to name the brand of glue remover you use. Is it Goop? Probably not since Goop is not likely found in the medical section.
I've used Goof Off, Goo Gone and the medical grade stuff to get adhesive off. I really like Goo Gone but they all seem to work the same. In a pinch, I've also used Bug and Tar Remover since it's a great paint-safe solvent.
